View Full Version : Disc Brakes
Pages :
1
2
3
4
5
6
7
8]
9
10
11
12
13
14
15
16
17
18
19
- Residual Valve for Vette 1" master and rear drum brakes? (4 replies)
- The Right Stuff Signature Brakes (27 replies)
- Get your Baer Racing at PTS (1 replies)
- Wilwoods (4 replies)
- Upgrading my brakes on second gen camaro (9 replies)
- How difficult? 95 Fbody front brakes used as rears on 65 skylark. (4 replies)
- Problems with brake booster, pedel stuck at the bottom ! (1 replies)
- Brake comparison (7 replies)
- What makes a SS flex brake line DOT? (14 replies)
- baer rotor alternative....? (1 replies)
- How about this set of C4 13" rotors and C5 calipers (23 replies)
- ebay disc conversion kit (2 replies)
- How much heat can stock 2nd gen F-body 11" rotors take? (7 replies)
- Rear Brakes for American Iron Car? (3 replies)
- Wilwood Master Cylinder Question (3 replies)
- wilwood super pedal (3 replies)
- C5/6 13" to 14" rotor (22 replies)
- old master with hydroboost (0 replies)
- Brake lines leaking (8 replies)
- 1.25" calipers with 1.0" rotors?? (3 replies)
- 64-F-85 with B-spindle disc up grade (2 replies)
- Can anyone Identify these Baer calipers (3 replies)
- 2010 Camaro Brembo Brakes on a 3rd Gen Nova?? (2 replies)
- Want Hydro boost on 69 and have questions (5 replies)
- What diameter for making your own hubs for the C5 brake kit 2nd Gen?? (13 replies)
- DBA Rotors (1 replies)
- Has anyone else had trouble getting a hold of Wilwood Tech dept? (6 replies)
- What is the BEST BUDGET ( BIG BRAKES ) for 9 inch ford? C5 Brakes or other? (14 replies)
- Looking for hubs made by Ed Miller? (6 replies)
- DSE Brake booster (30 replies)
- 68 camaro with 2010 camaro ss calipers (7 replies)
- Damage from back pressure on Master? (7 replies)
- Raybestos brake system ??? (0 replies)
- Will a Wilwood master cylinder work with the ATS T-56 install kit (5 replies)
- solutions for lose of vaccuum ? (3 replies)
- Emergency Brake/Parking Brake Mounting Options in First Gen Camaro (2 replies)
- 4th gen F Body: Wilwood 6S Fronts, 4S rears work good? (0 replies)
- Residual Pressure Causing Disc Brake Engagement (8 replies)
- Bad brake booster applying brakes by itself? (2 replies)
- 06 zo6 caliper logo removal (21 replies)
- C5 brakes/ master cylinder issues (3 replies)
- Looking for Speedtech C5 caliper/C4 rotor bracket for 1st gen Camaro (15 replies)
- newer truck hydroboost on first gen? (3 replies)
- New- What booster and master cylinder to run with Wilwood camaro fr Disc Brakes (1 replies)
- manual brake second gen F bodies (18 replies)
- 2004 Cobra brakes (4 replies)
- Baer 4262236 for 9" Torino Ends (5 replies)
- LS1 Brake Rotor Thickness (3 replies)
- Is braided really better? (10 replies)
- Sealant on brake fittings (2 replies)
- 13" C5 brake kit, sound too good to be tru? (9 replies)
- Pushrod extension? (5 replies)
- Knockback and leak advice needed (56 replies)
- parking brake options?? (18 replies)
- 6 piston caliper to suit 330 x 28mm disc (3 replies)
- Looking disk conversion for chevy nova 8.5 rear end (1 replies)
- 9" Ford Discs ?s (2 replies)
- anyone useing this? ssbc brakes? (13 replies)
- Help! Brake Lockup (3 replies)
- C6 Brakes (6 replies)
- c4 rotors with c5 calipers? (6 replies)
- Shops in NW Indiana/Chicago area (10 replies)
- Right front brake locks up before others (10 replies)
- Disc brake upgrade for 2010 Ford Fusion (0 replies)
- Wilwood 140-10996 problem?? (2 replies)
- anyone run Braided Stainless for brake lines? (11 replies)
- Brake lines (7 replies)
- Brake line pressures (33 replies)
- Wilwood advice? Any good rear disc kits w/parking brake to match Wilwood D52 kit? (17 replies)
- Looking for rear wilwood brake kit for GM 12 A body car (0 replies)
- Rear Disc Brake Setup for a Lowered G-Body (13 replies)
- Want a lighter budget minded brake MC (3 replies)
- Need Proportioning Valve HELP! (2 replies)
- MC1312A Master Cylinder problems?? (1 replies)
- big brakes???? (6 replies)
- Another brake squealing problem!! (4 replies)
- Need help with hydraboost install!! (0 replies)
- I need help with Master Cylinder (3 replies)
- looking for 1pc 13" x .81 rotor (1 replies)
- Old 10 bolt shot to he.. (9 replies)
- Baer part numbers? (5 replies)
- 69 Nova SSBC Quick Change Setup for Front - Problems (2 replies)
- Booster or no booster? (3 replies)
- Help selecting MC and a few other brake components (2 replies)
- New Wilwood issues-Am I just lucky? (6 replies)
- C5 rear calipers on LS1 backing plate (7 replies)
- Wilwood Brakes - 4 vs 6 piston/12.19" vs 12.88" rotors (14 replies)
- C5 brakes - 15/16" manual master - high effort & travel in pedal (15 replies)
- Need some help Brakes locking up. (5 replies)
- Outside pad wear? (6 replies)
- Blanchard Ground in metro-NY area, of ship them somewhere? (2 replies)
- Ford 9 inch disc brakes (5 replies)
- Some brake swap questions - 64 chevelle (2 replies)
- Pedal set-ups? (5 replies)
- aluminum two piston calipers...? 76 2nd gen/TA (11 replies)
- Help me find brake lines (3 replies)
- lt1 rear pads - why springs? (0 replies)
- converting to hydro boost (11 replies)
- Baer T4 Squealing?? (8 replies)
- Any forum vendors have Baer Track 4 front set in stock... (3 replies)
- First Gen F spindle upgrade (4 replies)
- scarebird disc brake swap (2 replies)
- Hurst Airheart ID inquiry (0 replies)
- Caliper mounting position (1 replies)
- Wilwood seals leaking (11 replies)
- 1969 F or X Body conversion to LS Brakes (12 replies)
- CTS-V Brembo 6 piston swap on a 1st Gen (141 replies)
- Camaro/Chevelle Spindles (7 replies)
- What proportioning valve? (3 replies)
- What disk should I run (8 replies)
- Wilwoods completed on 55 Belair with OEM lower controll arms (0 replies)
- Rear caliper direction? (3 replies)
- Wilwood D8-4 fronts, rear drums. Big car. What master? (2 replies)
- Master cylinder (2 replies)
- Wilwood parking brake setup (0 replies)
- Hydroboost and Z06's? (5 replies)
- Master cylinder plumbing (1 replies)
- Parking brake pedal assembly (1 replies)
- Speed Tech brake lines new products (1 replies)
- Need full Scarebird brake reviews please. 64-72 skylarks (0 replies)
- 73 Nova brakes? (1 replies)
- Upgrading Wilwood 2 piston to 6 piston..... (8 replies)
- Wilwood 14" 140-9804D Install notes (5 replies)
- 2nd Gen Brake upgrades.....? (7 replies)
- Stock LS1 E-brake to 67-69 Camaro (7 replies)
- What Master Cylinder for swap from stock power drum/drum to LS1 front/drum rears ... (3 replies)
- Good source forreasonbly priced NASCAR Wilwood caliper parts (3 replies)
- 72 camaro wilwood question (1 replies)
- Wilwood brakes, no pressure (4 replies)
- 14" Baer All Around. Will Manual booster work? (21 replies)
- dorman 7/8 m/c M39736 users (3 replies)
- Caddy Xlr-V rotors w/ LS1 calipers Will this work? (2 replies)
- Orederd Classic Performanc 12" brake setup (5 replies)
- Wilwood brakes, master cylinder and brake booster (2 replies)
- Excessive Pedal Travel (7 replies)
- LS1 Disc Brakes Locked Up (40 replies)
- Hawk HPS vs Carbotech 1521 (22 replies)
- Not PT Need help w/front discs 63 Bel Air (4 replies)
- What brand of disc brakes do you recommend? (13 replies)
- 11x1 GM rotor? (4 replies)
- WilwoodD-52 and dynalites on the rear? (0 replies)
- 68 Camaro Wilwood setup choices (2 replies)
- Stock C6 Zo6 drilled Rotor Vs DBA Aftermarket rotors (5 replies)
- Wilwood D-52 Caliper question (4 replies)
- Converted from manual to power brakes, where to put the booster vacuum line? (3 replies)
- CPP brakes any one use them (4 replies)
- What Wilwood caliper is this (9 replies)
- Big Brakes on A body with Billet Specialties 17 in wheels (8 replies)
- Swedge/expand brake line ??? (4 replies)
- C6 Grand Sport brakes for 68 Camaro (9 replies)
- Correct Master Cylinder for Manual GM Disc [D52 Calipers] and S10 Rear Disc app (6 replies)
- Booster pin pre-load? (5 replies)
- Got Wilwood? PTS has the deal for Pro Touring (0 replies)
- 69 chevelle four wheel disc question (3 replies)
- Hydratech vs ABS Electric vs Manual brakes (12 replies)
- do ZO6 Brakes bolt up to 67-69 camaro ATS spindle? (5 replies)
- Harder Brake Pedal? (11 replies)
- Looking for brakes for my frinds 71 firebird Formula (2 replies)
- Brake upgrade (2 replies)
- 98+ F Body Brake users check in. Quick Question (5 replies)
- Confused on brakes (1 replies)
- Here is another one guys. need help choosing the right brake pedal asamblie (0 replies)
- Good street/track brake pads (16 replies)
- 1977 Malilbu Master Cylinder Install (0 replies)
- 67 Factory disc upgrade (1 replies)
- Help (3 replies)
- Baer T4 rear brakes (5 replies)
- LS1 Rear Brakes (4 replies)
- banjo fitting question (5 replies)
- Need a new MC which is best? (13 replies)
- Front GM rotors with 1/2 studs ??? (0 replies)
- Wlwwod/Baer/ wilwood / Bear/Wilwood/Bear,I cant belive (13 replies)
- Ssbc @ in droppers! (0 replies)
- Brake Booster to manual brakes (1 replies)
- Really strange problem (3 replies)
- my most favoritest new tool (16 replies)
- 2010 camaro brembo brakes on 2nd f body (6 replies)
- Need help with a hub! (14 replies)
- Master Cylinder Install - Wilwood (3 replies)
- LS1 Brakes on 68 Firebird (4 replies)
- Front and rear disc size difference (6 replies)
- would this work (1 replies)
- LS1 brakes on 69 Firebird (2 replies)
- Hydraboost Specific Questions (18 replies)
- Master Cylinder Bore Size?? (4 replies)
- pedal feel on manual set ups, looking at wilwood pedal set up (8 replies)
- Brake Booster Question??? (6 replies)
- Wilwood 12.2" Brake/rotor kits, do they fit behind 15" weld prostars? (4 replies)
- 67 hydroboost? (3 replies)
- 2nd gen with 4 gen master cylinder (1 replies)
- ls1 brake kit for 2nd Gen needed (6 replies)
- Routing rear brake line (2 replies)
- Brakes (11 replies)
- LS1/S10 Rear Caliper Alternative (1 replies)
- 55 Chevy Power Booster Question (2 replies)
- LS1 rear discs on a 9" ford with GM ends (29 replies)
- ABS from LS1 - it's all in the details (8 replies)
- S10 rear disc conversion (4 replies)
- 1965 buick riviera 4 wheel disc (6 replies)
- Wilwood 260-8419 vs Wilwood 260-10922 (4 replies)
- S10 MC Plumbing Question (0 replies)
- Baer or Wilwood?? (18 replies)
- Mij new braking System (21 replies)
- Switching out DOT 5 silicone fluid (4 replies)
- whats the difference? (8 replies)
- GTO brakes (2 replies)
- Good general brake system info (1 replies)
- Emergency brake cables on back-halfed 1st gen ?? (19 replies)
- brake bias questions (9 replies)
- good buy? (7 replies)
- Brake noise? (5 replies)
- Larger rear rotor w/lt1 caliper (6 replies)
- hydro boost on track (7 replies)
- major brake issues PLEASE HELP !!!! (5 replies)
- Negative offset? (3 replies)
- G-body brake upgrade, alot of options, and questions. (12 replies)
- Wilwoods/Lokar Cable..... Again (3 replies)
- wilwoods (6 replies)
- MustangII clip/Big brake ?'s (6 replies)
- Newest info from Baer Brakes regarding their Full Floater (2 replies)
- What brake line fitting do I still need? (6 replies)
- Inverted flare or -AN fitting for stainless brake lines (23 replies)
- Brake line? (1 replies)
- Weak brakes on a '55 Bel Air (disc/disc) (2 replies)
- Brakes for 79 Z28 (7 replies)
- power brake problem (1 replies)
- Are braided steel Parking brake cables worth the money? (2 replies)
- Moser 9" for 67 Camaro - LS1 brakes? (4 replies)
- how much clearance should i have between the caliper and rotor face. (12 replies)
- custom rear disc brake brackets (6 replies)
- old baer track system rotors ? (3 replies)
- Sealant on pipe threads into proportioning valve? (3 replies)
- mc for track baer system (4 replies)
- best budget brake upgrade (12 replies)
- Added rear discs, now no pedal (16 replies)
- is the early 70's vette master cyl a direct bolt in on a first gen? (2 replies)
- extra extra novice here! (12 replies)
- Emergency Brake Cables GM A Body and Wilwood Brakes (4 replies)
- Hydratech Line Pressure & 700 Versus 600 Series Steering Box (1 replies)
- Brake line size for LS1/Corvette brakes? (5 replies)
- what master cylinder will work? (5 replies)
- ls1 conversion help (2 replies)
- C5 on the R10 (5 replies)
- Baer experts chime in, rear brake issue (5 replies)
- Wilwood BOP rear disc brakes? (7 replies)
- simulated rotors (22 replies)
- Master cylinder- C5 caliper problem. (1 replies)
- Wilwood Disc Brakes (1 replies)
- Newly installed LS1 brakes scraping... (1 replies)
- LS1 vs. S10 Rear Disc on 2nd Gen Firebird (12 replies)
