    Results 1 to 10 of 10
      Old 10 bolt shot to he..
      Does 10 bolt 8,2 drums fit the newer 10 bolt 8,5 with discs?
      All under 6.27 litres is a starter.
      USA
      Are you asking if your drum brake setup from an 8.2 10 bolt will fit onto an 8.5 10 bolt ??
      Jeff Tate
      U.S.A.
      Yes exactly!
      Holmes Hollow, Ontario Canada
      Its the same bolt pattern. So yes. But why would you remove discs?
      ____________________________________________
      Scott
      So that you can't see that the axle has been changed,
      Well, if you are swapping the rear end from a second gen f-body to first gen f-body, the 8.5 is 1" wider than the first gen camaro 8.2 but the same width as the first gen firebird. The leaf pads are in the same or almost the same spot though. The diff cover is different and the pumpkins have different tabs. So no one is going to know if you are looking at it from the wheel but they will from rear. On the other hand, I may be wrong but I think you may have problems if you are only swapping the axles. Are you swapping the axles or the whole rearend? Just out of curriosity, why is it more important to not know that the rear has been swapped than to have disc brakes?
      Scott
      Jun 2011
      Vette City, USA
      Assuming it does fit and you can get it hooked up, you could grind the ears off the 8.5 housing to camouflage it to look like an 8.2. If you do that, I'd bet most people won't have a clue which rear it is without climbing under the car and having a close up look.
      Old enough to know better, young enough to think I can get away with it.
      They also have a different diff cover I think.
      Scott
      Jun 2006
      Katy,TX
      But you know since it isn't a 12 bolt must not have an horsepower right
      Bet most folks woulddn't notice the difference.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Jun 2011
      Vette City, USA
      They may have a different cover but they are interchangeable as far as I know. I think all GM 10 bolts, truck, car, 8.2, 8.5, chevy, BOP all take the same gasket. I even think you can put a chevy c-clip cover on a BOP bolt-in housing but not the other way around.
