    Results 1 to 7 of 7
    Thread: big brakes????
      May 2010
      Morristown, Tennessee
      big brakes????
      I have a 69 camaro;
      question to you guys is...
      Is their a Kit or set up out there that can give me 13" rotors and
      calipers that bolt to the regular locations, so as to
      where i dont have to change my spindles??
      Oct 2010
      Santa Ana, CA
      CPP Makes a full kit stock or upgrade to a 2" drop spindle
      Havii Gonzalez, OC Calif.
      68' MARO - UNDER FULL RESTO - LSX ect..
      Used to be known as stilo
      Mar 2010
      Hi Kevin, we have everything from 10" Drag Brakes to giant 13" & 14" Big Brake Kits that will bolt to your spindle. Call one our dealers that regularly BLOG on this forum for details.
      Ken H
      Wilwood Tech
      Wilwood Disc Brakes
      www.wilwood.com
      Roswell, N.M.
      Give Jon at Scotts Hot Rods a call 1-805-485-0382. Very informative and great pricing on Wilwood...
      Apr 2004
      OKC, OK
      Baer has their Track 4 setup that will work with stock spindles. The more important question is what wheels you have will depend on whose brake caliper will clear.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Cartersville, GA
      BRP/Musclerods has a new kit out that uses the stock spindle:
      Our NEW 13” Front brake kits are designed for use with early GM 2-piece spindles. They require the use of 17” wheels or larger (we cannot check fitment with all wheels, so please verify fitment prior to ordering). The kit includes all NEW parts including GM 2-piston calipers (with high performance brake pads), drilled, slotted & coated 13” rotors, stainless steel braided brake hoses (front only), brackets, shims and hardware. If ordered with our modified hubs you get the modified hubs, new longer wheel studs, new bearings & seals. (Note: there is a $40.00 core charge on the hubs)
      Retail from them is $849 without hubs/$949 with (not including the core charge)
      I'll sell them to Pro-Touring members for $799/$899 respectively, plus the core. be sure to specify if you have drum or disc spindles.
      Joe Hinds
    Tags for this Thread
