    Results 1 to 11 of 11
      Jun 2006
      NW burbs IL
      Right front brake locks up before others
      Any ideas on what can cause this? More or less weight on right front? Alignment?
      I would like any and all ideas that can cause this, so I can start troubleshooting.
      Thanks, Matt
      Matt
      May 2002
      Southeastern WI
      My first thought would be air somewhere in the left side.
      Jeff
      Feb 2010
      Corvallis Montana
      sounds like a plugged line what you need to do is get a pressure bleeder and run all the old fluid out if you don't get and fluid out of the left front try taking the hose off the caliper if no fluid out of the line take the hose off the steel line if no fluid out of the steel line go to the master cylinder. if you are getting fluid out of all 4 corners you probably have a stuck caliper the one on the left side is probably the one stuck. hope this helps.
      HILLBILLY HOLLYWOOD, TENNESSEE!!!
      Look at the rubber hose at the wheel that locks up first.
      Rubber hoses are cheap. I would go ahead and replace both front and the rear rubber brake hoses if the car is old and you have never replaced the hoses. The rubber hoses break down from the inside out. What "may" look good can be bad.
      A $30-$60 parts cost and a great time to change that old and nasty brake fluid.
      Mike
      Remember, "Drive Fast, Turn Heads, Break Hearts!"
      www.musclecardeals.com
      Jun 2006
      Katy,TX
      X2
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Henderson,NV
      Is this at threshold braking? My RF locks up first at threshold as well. Your LF or RF better lock up first. If this is before threshold, then you have a problem.
      Todd
      A bad brake hose will not completely release brake pressure when you take your foot off the brake pedal when compared to a good brake hose thereby causing the brake with a bad brake hose to already have some amount of residual pressure in the brake caliper/wheel cylinder before you apply the brakes. That already present residual pressure results in the brake with the bad brake hose applying more pressure immediately to the caliper/wheel cylinder at that brake location when you step on the brake pedal and therefore causing the wheel to pull in that direction under braking or locking up way before the opposite brake with the good hose.
      In extreme conditions I have had a bad brake hose lock up the brake in question with no brake pedal input and causing the brake to smoke if driven or completely lock down.
      For a $100-$120 you can generally buy braided performance brake hoses. These hose provide a much more firm pedal and are a great upgrade for anyone interested brake performance.
      Mike
      Just North of NYC
      Does the car pull under braking? The other caliper could be seized or binding somewhat and just not braking as much as the one that is locking up.
      Also, if your car was ever whacked, your corner balance could be way off. A "lighter" corner would lock up first. A local raceshop or Porsche tuner should have the scales and may be willing to help you if that's the case.
      Jun 2006
      NW burbs IL
      I finally have some time to respond. Great ideas guys, Todd it is at threshold. The car is setup with aftermarket everything. Braided lines, aggressive pads, floating calipers, and I know they are releasing. I do not have any pull while braking. Ken maybe on the money, my right front corner weight is 63 lbs lighter with me in the car. Although the pic I saw from motorstate I believe had a passenger onboard, so i'm thinking it may have had more weight on that corner. Hmmm well I'll get my step son to help me give it a good bleed and I'll test with and without him in the car. I'll be back!!
      Matt
      Oregon
      It sounds like you're on the right track, the only thing I would add is that you should verify that your air pressures are equal side to side since that effects traction levels and therefore threshold braking and lockup characteristics.
      Tobin
      KORE3
      It's what I does.
      Elgin, IL
      Matt,
      Let me know if you need a hand or a foot, I am just down the street.
      Dan
