Results 1 to 4 of 4
Thread: I need help with Master Cylinder
06-07-2011 #1
- Join Date
- Sep 2005
- Location
- Central Illinois
- Posts
- 152
I need a smaller bore master cylinder and need help with the application.
Here's the vehicle specs:
'68 Olds 442
Vehicle has power brakes and a spicy cam that pulls about 13" of vacuum at idle
Front brakes: C5 'vette with 13" baer rotors and Hawk HPS pads.
Rear brakes: 11" Ford Exploder with factory pads.
No prop valve. I use a DPI racing Lock Resistant Dampener in line on the rear brakes. It's a valve that dampens and delays the rear brake on high pressure spikes (oh sh*t!) and keeps the rear from locking. It's been on there for years and worked fine when I had 12" 1LE brakes on the front.
Currently I'm using a '79 Trans Am master cylinder for 4 wheel disk. I'm not sure what size it is, but I'm guessing 1-1/16?
The pedal is really firm. It's fine for normal driving, but in a panic stop situation the pedal is hard as a rock and I have to give it everything I got. It scares me. I know I need a MC with a smaller bore to build more pressure. From what I've read, a 15/16" bore seems to work for most people. My problem is what application. I'm looking for MC that looks like what I have. A new style aluminum/plastic unit might save weight, but would look out of place under my hood, which has a stock restored look. I would be willing to settle for one of those ugly Corvette bath tub looking ones if I had to. I've heard the '78 Malibu has a 7/8" bore, but I think the lines are swapped front to rear, and I don't want to alter that. I have nice stainless lines and all.
Any ideas?
'68 442 convertible
5 SPEED - EFI
'66 442 Hardtop
in process
