Results 1 to 8 of 8
Thread: Brakes for 79 Z28
11-28-2010 #1
- Join Date
- Nov 2004
- Location
- Gilbert, Arizona
- Posts
- 50
Brakes for 79 Z28
I am trying to compile a Christmas wish list for my wife. Right now, my camaro has stock brakes front discs and rear drums. I have purchased C5 calipers, abutments, and rotors. I still need the rest of the kit(hub, brake lines......etc). I would like to eventually install either the LS-1 camaro rear disc set up or a WilWood rear set up. I am looking at the Wilwood master cylinder and was wondering if I should use a 1" or an 1 1/8" and also if I should use the stock brake booster or upgrade to a double diaphragm type. My vac on my car is marginal at 18. Would I be better off switching to manual brakes and going with a 7/8" master cylinder? Also, would I use the factory distribution block until I switch to rear disc? Then do I need to swap that out or can I use a proportioning valve? Thanks for any help
Z-28 has a built 383SBC. The heads are AFR 195 CNC ported with a 274 Solid Extreme Energy Cam. 1.6 rockers an Edelbrock RPM Air Gap intake and a 650 Holley carb. Turbo400 with a 10" ATI convertor 3200 Stall. 3.42 posi. Hotchkis springs/swaybar/UCA and Bilstein shocks.
