    Results 1 to 4 of 4
      Garwin, Iowa
      Sealant on pipe threads into proportioning valve?
      What is the best thread sealer to use on my pipe adapters into my wilwood proportioning valve? I've read a post about this before but I can't seem to find it again. Loctite 545 comes to mind, but not sure if that is correct.
      Southern Indiana
      I have been using either the liquid thread sealant , just the plain white stuff in my box, but miss the first full thread. OR Carefully ,,,missing the first full thread to thread and a half, and use the yellow gas pipeline thread tape I get at Lowes or Menards, its much thicker and seals very well.
      There are other thread sealants but Idont have my chart.
      Lee Abel
      AFTERMARKET PERFORMANCE
      USA
      I always use the yellow gasline sealant (Rector-seal) , from a hardware store.
      It hardens a prevents leaks.
      I put it on the bleeder screws too , to prevent air being pulled past the threads when bleeding or flushing the brakes too.
      Jeff Tate
      U.S.A.
      Elgin, IL
      I like # 2 Permatex not so sensitive to being spotless clean and it still seals if you have to back off to say..aim a 90* fitting in the right direction. It kind of looks like your kids first pooh but works great.
      Good Luck
