View Full Version : 2010 camaro brembo brakes on 2nd f body
miahbuchholtz
01-24-2011, 08:49 PM
i have stk brembo brakes off a 2010 ss camaro and does anyone make retrofit kit to make the any of it work any help would be great. im like to put it on a 77 trans am
Apogee
01-25-2011, 12:38 PM
The Brembo brakes from the 2010 Camaro SS don't play nicely with the second-gen F-body spindle (GM tall-spindle) due to the quite long mounting ears on the caliper castings. You can only cut so much material off of the GMTS spindles before you start to impact its structural integrity, so that means if you're not interested in running 390mm [15.6"] diameter rotors or larger, then look elsewhere. Probably not the info you were hoping for.
Tobin
KORE3
miahbuchholtz
01-25-2011, 08:45 PM
thanks that helps ill like in to different set
bobbaganoosh
01-26-2011, 10:27 PM
Ok I've been thinking this over, I think it would work but I might be full of crap so bear with me here:
For the '98-'02 F-bodies the C6 Z06 rotor & Cadillac CTS-V calipers is essentially a bolt on. There are kits that adapt the stock F-body brakes from the same years to B body GM spindles. Wouldn't that make the big brakes a bolt on for the B body spindles w/kit as well? Why not convert to B body spindles? I've heard the Camaro caliper is the same as the Caddy one with the exception that the Camaros' mounting bolt holes are bigger.
nobreaks254
07-12-2012, 05:14 AM
anyone know any more about this?
pandatime
07-12-2012, 04:21 PM
i follow your train of thought. sounds like the 1LE swap but you'd be best to check a B-Body forum or something? Could be onto something. Sounds too easy
Skip Fix
07-13-2012, 05:59 AM
B body spindles are basically F body with the caliper holes a little further out. Dust shield bolt holes that most kits use for caliper brackets are the same though.
