View Full Version : LS1 Brakes on 68 Firebird
Bob's68
01-19-2011, 08:17 PM
My understanding is that the rears directly bolt up, how ever what about the fronts? That is my question if i could be linked to another thread, or website. Much Thanks.
I know it has probably been answered before.
edit: What about using the booster?
My firebird is manual brakes and four wheel drums.
DEIGuy38
01-19-2011, 09:29 PM
Call Kore 3 talk to Tobin
http://www.kore3.com/
rickpaw
01-20-2011, 12:25 PM
Check out John's website (link below-scroll toward the bottom of the page). He did a full LS1 brake conversion on his 67 Firebird.
http://john.my67.net/Suspension.htm
nickv
01-22-2011, 09:05 AM
I used a Kore3 C5 kit on the front (also have ATS AFX spindles) and a 79 Trans AM setup on the rear of my 69.
Kore3 has all the brackets you need if you use the stock spindles. He also has a kit that will work on a 10 or 12 bolt in your 68. The prices are extremely reasonable and flat out work.
My next upgrade will be the 13" rear kit.
www.kore3.com
Good luck
Nick
PRO69TA
01-22-2011, 12:31 PM
I used the adapters made by Speed Tech on my 69 Firebird. I used the LS calipers with 13" Corvette rotors (also had to use the Corvette brackets for the calipers). There are also several sites with a pattern to make your own if you have access to some basic fabrication tools. Quick Performance sells a Ford 9" with the LS flanges that I'm going to use on my next project.
