    Results 1 to 19 of 19
      IN/MI border
      parking brake options??
      Have a wilwood hat kit for the rear but no parking brake. I know there is a mechanical setup but I'd need to make my own brackets. Any other feasible solutions out there or should I sell this kit and get a kit with internal drum parking brake setup?
      Dec 2010
      Fredericksburg, VA.
      What rear end are you running? Speedway Motors sells a 9" Ford pinion mounted E-Brake kit for $299
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Oct 2008
      Durham,NC
      Know the feeling there Buddy I have problem with no ebrake idea for using c5 vette brakes on my 12 bolt Chevelle. Pinion mounted is a good idea but never found one for cheap on a 12 bolt. Brandon
      IN/MI border
      Yeah i have a 12 bolt. A pinion mounted would be nice.
      Jun 2008
      Western Washington
      Did you see the most recent update on Project Unfair in Super Chevy?
      They use a mechanical hydraulic line lock inline to the rear brakes to use the rear caliper as a Parking Brake...
      pg105
      "Step Brothers"
      Pro Toured 95 Pontiac Trans Am (Green Dragon)
      Full Frame Build 69 Camaro (Night Hawk)
      -Luca Z
      Dec 2010
      Fredericksburg, VA.
      I read that article and IMO the hydraulic line lock is not a good idea. A mechanical park brake is designed to be engaged and can be left in that state indefinately. A line lock, like any hydraulic system, will bleed off pressure over time which could result in the brakes releasing at some point. I would also be concerned that prolonged pressure in the rear calipers could cause them to fail in normal operation.
      May 2010
      Ontario
      Not to mention that a cable operated e-brake will offer some stopping power should your hydraulic brakes fail. Yes, diagonal split braking systems are designed with this situation in mind as well, however stranger things have happened.
      -Pat
      Jun 2008
      Western Washington
      I'm pretty sure the line lock can ONLY be qualified as a Parking Brake, they are getting by the DOT e-brake requirement by having a completely separate brake lines and master cylinders (I think).
      As for TheJDMan's thoughts, I would tend to agree that there will be some bleeding off but who knows how long it would be before it allowed the brakes to slip and as for the prolonged pressure causing issues I would "hope" that doesn't happen but that would be a question for the designers of the calipers.
      Good valid concerns though!
      I myself have separate mechanical e-brakes and feel much more comforted with them over using the same rear caliper for stopping and parking brake.
      Except my Lokar e-brake cable kit has failed multiple times, because the crimped fittings on the end of the cables just pop off!!! So I am searching for a better/more reliable solution to an e-brake cable.
      "Step Brothers"
      -Luca Z
      Dec 2007
      Carlsbad, Ca
      i too thought about jp's newest article and like the approach with eliminating the cables. i also agree with the issues that are posted above. i think it would be better if the lack of fluid caused the brake to set rather than relying on a closed system to keep constant pressure. same theory behind maxi brakes.
      if you need them, this place gets the best reviews. it sounds like they make an oem style cable and dont have the failures that plague the lokar cables. i even read that tobin likes them. http://store.controlcables.com/servlet/StoreFront
      Tim
      Build Thread Link
      Jun 2008
      Western Washington
      Thanks for the website, I have been looking for them. I called them quite a few months ago to ask them some questions and I never ordered because my car is 700 miles away from me so I couldn't measure anything and I lost their information.
      Thanks!!!
      Sorry for the high jack...
      "Step Brothers"
      -Luca Z
      Nov 2010
      Yea I have heard about control cables as well!!!
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      Dec 2010
      Fredericksburg, VA.
      Somewhere I saw a picture of a rear disk park brake setup which consisted of a main service brake caliper and a second seperate mechanical park brake caliper. I only saw the picture once and I have never been able to find it again but I liked the idea of a second smaller mechanical caliper for the park brake completely independent of the service brakes.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Jun 2008
      Western Washington
      Would it have been my setup you are talking about?
      https://www.pro-touring.com/showthre...amaro%29/page3
      I am using a Mr. Parker Mechanical caliper for the e-brake/parking brake. I bought it from a company called Precision Brake Company (but they are now Revolution Brake Company). But I will warn you they were VERY flaky when I dealt with them 4-5 years ago, they might have changed since then.
      Wilwood also makes a separate mechanical caliper but it doesn't look as nice as the Mr. Parker, and I cannot find the Mr. Parker anywhere else.
      "Step Brothers"
      -Luca Z
      Feb 2007
      Vancouver, WA
      Quote Originally Posted by GrnDragon View Post
      The new barrel end I used is a 3/8” dia x ½” long hollow steel spacer I got at the hardware store. It’s the same size as the barrel on the end of the stock LS1 cable. Drill a 1/8” hole through the spacer, and slide the cable through. Heat the spacer with the cable passing through it cherry red and melt in some thin flux covered brass brazing rod. I used a MAPP gas bottle with a standard propane tip and it worked fine as long as the material I had it clamped to wasn’t too thick. I wound up clamping it to an old sawzall blade which was clamped in a vise and it worked great.. An acetylene rig would make it super simple.
      Orlando, Fl
      Early vipers had a separate parking brake caliper as well. Another good source.
      Nick DiPrenda
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by dipren443 View Post
      That made me curious so I did a google search on Viper park brakes and found this site.
      http://www.ipsco.org/Viper_files/par...kekitViper.htm
      Does anyone have any experience with this company?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Dec 2010
      Fredericksburg, VA.
      I also found this park brake kit from Brembo but this one is a bit spendy.
      http://www.roeracing.com/productcart...?idproduct=370
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Orlando, Fl
      Quote Originally Posted by TheJDMan View Post
      This kit looks like it uses the cheap aftermarket spot calipers available. I personally would prefer to just get used OE Viper calipers and retrofit them.
      The OE calipers look eerily similar to the ones included in the Brembo kit you posted in your most recent response.
      http://compare.ebay.com/like/3002769...=sbar&_lwgsi=y
      Nick DiPrenda
      Melbourne, FL
      Might want to check out these guys ...
      http://www.tsmmfg.com/2181.htm
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
