wmhjr
04-16-2011, 02:00 PM
Guys, for those of you who have installed the Wilwood parking brake kit on your Wilwood rear discs....
If you installed it in a non-standard setup or for any other reason needed to cut the sleeve length, did you find there are any issues to consider other than just using a tubing cutter or whatever to carefully trim it? I'm in the midst of installing mine (finally) and just wanted to check if these things disintegrate or anything when you trim them.
Thanks!
Thanks!
