Results 1 to 20 of 142
04-26-2011 #1
- Join Date
- Feb 2011
- Posts
- 9
CTS-V Brembo 6 piston swap on a 1st Gen
Hey Guys and Gals,
I've owned my Camaro since '94. It's a L34 w/ RS options. I hate to "cut up" the car, The Gul Mod, solid bushings, and sway bar in the front are done.The 4 piston irons just don't stop the way I would like them to. Other than the obvious caliper, what else do I have to look forward to. I will be buying parts/pieces as I can afford, so a kit isn't an option. I bought another set of stock upper and lowers w/ drums and understand the machining of the front hub. Which spindle of the two (if there is a diff) is stronger? Which hat/rotor should I use? 13" 14"? What brackets? Lines? I'll be buying wheels later to fit the set up. Please help! My brain hurts.
