Results 1 to 9 of 9
12-31-2010 #1
New to Pro-Touring
- Join Date
- Dec 2009
- Posts
- 26
ABS from LS1 - it's all in the details
I've been conversing with some of the members about adapting the ABS to my 64 Skylark ragtop along with the entire LS1 transplant. I thought it might be best to start a new thread because the other thread was more about ABS in general.
The help from other members had been amazing and I think I'm on the right track for success. I bought a totalled 02 SS Camaro with the LS1 6 speed which is now sitting in the Skylark. I've adapted the steering column and pedal set up from the donor as well. My plan is to have all the luxuries that came in the Camaro, cruise, ABS, traction control.....
The system is a four channel and has the sensors at the rear wheels. To use it, I'm adapting the whole rear brake set up to a 9" with the reluctor rings pressed on the axles. For the front I'm using ATS AFX spindles with sensors and ordered a front C5 brake package from Kore 3 but without the calipers. I will use the calipers from the donor car to keep the piston sizes correct for the front and rear.
So.. here is the next hurtle. I wanted to go with a little taller tire than what the Camaro had. I know that the tire diameters front to rear need to stay close for the ABS to work properly. I had planned on adjusting my rear axle gear ratio to compensate for the larger tires, that way I could keep the speedo correct and stay close to what the factory RPM ranges were for the LS1. But if I do that, the wheel sensors will be traveling at a different speed then the trans speed sensor.
The question is does the ABS or traction control set up look at the trans speed sensor as well as the rear wheel sensors or are they completely independant of each other? If they do look at the trans sensor, then I would need to stay with the LS1 diameter wheels and gear ratio correct?
This is a great site and the help has been great. Thanks to all.
12-31-2010 #2
- Join Date
- Aug 2004
- Location
- San Antonio, Tx
- Posts
- 1,193
you can have the speedo adjusted with a tune. the EBCM doesn't look at the trans speed sensor.
you can change the tire size to what. the camaro had 275/40-17 stock, so they were 811 revs per mile. now you need to stay within 3% max front to rear. from searching what tires sizes people are running and playing with different sizes on my vette it worked out just fine. i am running 295 fronts (798 rpm) and 335 rears (802 rpm) so we are talking 4 rpm different. that difference could be the same as a new 275 vs a worn out 275. also i am running a 9" with the reluctor wheels on the axles and ats spindles.Instagram: CamaroAJ
12-31-2010 #3
New to Pro-Touring
- Join Date
- Dec 2009
- Posts
- 26
Excellent! That's what I was hoping for - that the ABS sensors and trans speed sensor don't pay attention to each other. Since I need to build a rear anyway, I will first decide on wheel / tire size and then set gearing ratio to make up any difference. That way I will have the motor rpms close to the LS1 stock arrangement. Who knows, I may not even have to do a tune for the speedo.
Thanks again.
12-31-2010 #4
- Join Date
- Aug 2004
- Location
- San Antonio, Tx
- Posts
- 1,193
you won't like it if you run it so its close to stock gearing. a lot of people complain that 6th isn't usable and bucks or surges. i had 3.50 gears in my '67 and it was the same way. common gear for ls1/t56 is 3.90 or 4.11, with a 27" tall tire in 6th @ 70mph thats still around 2300 rpm.
Instagram: CamaroAJ
12-31-2010 #5
New to Pro-Touring
- Join Date
- Dec 2009
- Posts
- 26
10-22-2012 #6
- Join Date
- Oct 2012
- Location
- mi
- Posts
- 1
