    Results 1 to 15 of 15
      Jan 2011
      Boston, MA
      Wilwood Brakes - 4 vs 6 piston/12.19" vs 12.88" rotors
      As the title suggest, looking for opinions on Wilwood brake setups for my '67 Camaro (currently 4 wheel drums). I have 18" wheels so anything will fit. My biggest problem is that I don't know how much/if any track time the car will see.
      There are a bunch of kits out there from the 4 piston/12.19" rotor setup, to the 6 piston/12.19" setup, to the 6 piston/12.88" rotor setup for the front.
      12.88" rotors for the rear don't seem necessary for a mostly street driven setup, but what do you guys think about the front. Is there a big difference in stopping power, heating/cooling, etc? It's a pretty big jump in price from the 12.19" rotor to the 12.88". Is it worth it?
      Last thing is that I will probably upgrade the rear end after the summer, so I may hold off on rear brakes until I figure out what I'm doing with the rear. Thanks.
      Aug 2003
      Orlando, FL
      The 12.19 is great for dailey driver, casual autocross (casual being the operative word). I run the (6) piston 12.19 front and (4) piston 12.19 rear on my street drag car and stop from 148MPH at the shortest tracks with room to spare and then some. Stopping power is great. And for $2100 for a complete F and R kit that does the entire car with master, ebrakes cables, etc, and all the goodies, you cannot beat it for a great looking set up in a 18" wheel and terrific performance.
      Jan 2011
      Boston, MA
      Will the rear brakes fit the standard 7/16" studs or does the rear axle need to be redrilled and tapped for 1/2" studs?
      Aug 2003
      Orlando, FL
      We have a lot of people run them with the 7/16 studs, and if you tighten the wheel properly it whould be OK. but with that said the front hubs are going to be 1/2" with the Wilwood front kit. Your going to have th axles out anyway for the install (which is pretty simple) so i would just have 1/2" studs pressed in. Any auto parts store with a press can do it.
      Jan 2011
      Boston, MA
      Alright, interesting. For some reason I thought the fronts used the 7/16" studs. I'm still not sure I want to put any time or money into this 10 bolt 8.2 that I have.
      How much of a savings (dollars or % off) is it to buy a kit for front and rear with all the goodies, vs piecing it together (doing the front now and the rear when I do a new rear end). Assume I did 6 piston 12" rotors up front and 4 piston 12" rotors on the rear.
      Aug 2003
      Orlando, FL
      The Total Car G Machine package is right at $400 less then the individual components but we can save you some money if your doing front now, rear later.
      Petaluma Ca.
      Frank, could you please get me more info on the kit for $2100.....
      Looking for a complete kit for my 67 camaro, also 18" wheels.
      Sep 2010
      Otsego, MN
      I have 13" - 6 piston on the front and 4 - piston 12" on the rear of my Fairlane. Couldn't be happier. Stops great and makes me feel much safer. This was an upgrade from the 4 wheel drum setup!!
      "Project Scarelane" - 1967 Ford Fairlane 500XL Pro-Tour
      Aug 2003
      Orlando, FL
      67Rally, your stuff shipped and is on the way, Thanks for the order.
      Aug 2003
      Orlando, FL
      Quote Originally Posted by brandonc707 View Post
      Brake kits are here, Your loking for the Street Package with (6) piston front upgrade and (4) piston rear.
      http://www.protouringsuperstore.com/...s.asp?cat=2662
      Jan 2011
      Boston, MA
      Quote Originally Posted by ProdigyCustoms View Post
      Frank, just got back from the long weekend. Thanks for going out of your way to make this happen. I'll let you know how they work out.
      I'll give you a call when I'm ready to do the rears.
      Jan 2011
      Boston, MA
      Christmas in June! Thanks Frank!
      Wilwood 140-10510-DR 12.19" black drilled/slotted rotors with red 6 piston DynaPro calipers and polished master cylinder:
      Close up of the calipers:
      Nov 2014
      Country Flag: Brazil
      67rally, those brakes fade when they get hot? Because i ride in some twisted roads and those goes down hill. I'm little bit worried about that.
      Jan 2011
      Boston, MA
      Quote Originally Posted by JackSS View Post
      I haven't tracked it, so I can't tell you for sure. No issues with hard backroad/around town driving though.
      FWIW, those were the wrong calipers that Frank sent. I think they were Superlites, or something better than the Dynapro's. They did not fit the brackets. The Dynapros are nice, but not as beefy as what's puctured above. I'll see if I can dig up a pic.
      Jan 2011
      Boston, MA
      Superlites on top, Dynapros on bottom:
