View Full Version : 6 piston caliper to suit 330 x 28mm disc
Ivan Vella
07-19-2011, 06:07 PM
Does anyone know of a 6 piston brake caliper that would suit a 330 x 28mm disc rotor other than Wilwood?
I have purchased front brake rotors but to avoid problems with brake balance (the rears are 4 pistons) I would like to get 6 piston calipers for the front.
I have no problems machining custom caliper brackets if required.
It is to go onto a 69 camaro running 2" drop spindles and Rushforth X rated rims.
Any help would be greatly appreciated.
andrewb70
08-08-2011, 05:51 AM
The issue is not just the number of pistons but total piston area.
dipren443
08-08-2011, 05:31 PM
Andrew is right.
Regardless, these AP calipers *may* suit your needs. They fit your rotor diameter and thickness specs.
Four Piston
http://www.apracing.com/info/products.asp?product=4+Piston+Calipers-CP5200+Family+-+152mm+Mounting+Centres+-+16.8mm+thick+pad%3Cbr%3E%3Cimg+border%3D%222%22+s rc%3D%22http%3A%2F%2Fwww.apracing.com%2Fpics%2Fpro ductpics%2Fcp5200_1.jpg%22%2F%3E_2759_2569
Six Piston
http://www.apracing.com/info/products.asp?product=6+Piston+Calipers%2DCP5570+Fa mily+%2D+Suits+%D8330mm+Disc+%2D+17mm+Thick+Pad%3C br%3E%3Cimg+border%3D%222%22+src%3D%22http%3A%2F%2 Fwww%2Eapracing%2Ecom%2Fpics%2Fproductpics%2Fcp557 0%5F2%2Ejpg%22%2F%3E_2763_2570
Apogee
08-15-2011, 10:40 PM
X2 about Andrew being right, we need more information. What's the application? What size rear rotors are you running? What is the rear caliper piston area?
Tobin
KORE3
