    Results 1 to 15 of 15
      Jun 2006
      Katy,TX
      What makes a SS flex brake line DOT?
      So what's the difference in a DOT vs a race line?
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Sep 2004
      Fresno, Ca
      Skip,
      I believe it's something called a Whip Test. The line is subjected to immense stress and whipping about to ensure it doesn't come apart.
      Cartersville, GA
      Poncho is right. It doesn't mean that a hose that doesn't have it is unsafe, just that the manufacturer didn't pay to have it tested. I'd stick with DOT stuff just to be safe on a street car, though.
      Joe Hinds
      Jun 2006
      Katy,TX
      Thanks.
      So your dad's 61 in the picture have a 348 in it?
      2004 Pulse Red GTO
      Cartersville, GA
      My dad's '60? It was a 348, with 12.5:1 Jahns pistons and a solid cam. The coolest thing about the car, to me, was the widended steel wheels in the rear...built by a local drag racer named Ronnie Sox. I wish he still had it, but its pretty cool seeing it on TV from time to time.
      Joe Hinds
      Loganville, GA
      Skip, Kore3 has DOT SS braided lines. See here http://www.kore3.com/categories.php?cat=10
      The FAQ on the Kore3 site mentions DOT compliant FMVSS-106, so here is what the test says from the gov standard
      Standard No. 106 - Brake Hoses - Passenger Cars, Multipurpose Passenger Vehicles, Trucks, Buses, Trailers, and Motorcycles, and Hydraulic, Air, and Vacuum Brake Hose, Brake Hose Assemblies, and Brake Hose End Fittings for use in those vehicles (Effective 1-1-68)
      This standard establishes performance and labeling requirements for hydraulic, air, and vacuum brake hoses, brake hose assemblies, and brake hose fittings for all motor vehicles. The purpose of this standard is to reduce brake system failure from pressure or vacuum loss due to hose or hose assembly rupture.
      It doesn't really say what the standard is on that site so it doesn't fully answer your question. The whip test is what I hear the most about. Curious if anyone knows what the whip test actually is?
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Rustburg, Virginia
      just a note: SpeedwayMotors.com also has DOT SS flex lines. I used them on my car.
      Orlando, Fl
      Quote Originally Posted by BulldawgMusclecars View Post
      As in THE Ronnie Sox?
      Nick DiPrenda
      Oregon
      The most common failure point for braided stainless brake hose assemblies is at the fitting during the "Whip Test" due to work hardening of the stainless wires leading ultimately to broken wires which then serve to errode and puncture the teflon tube that it's supposed to be reinforcing. There have been several methods by which various companies have achieved DOT compliance over the years, some of which are inherent to the hose and fiting designs and others which are added to the hose assembly during construction, such as the urethane collars where the hose and fittings are swaged together.
      Tobin
      KORE3
      It's what I does.
      Jun 2006
      Katy,TX
      I've been making and buying some specific fitting pre made ones for the drag car, as well as plumbing the pressure gauges and had just noticed some said non DOT.
      Thanks for all the explanations.
      2004 Pulse Red GTO
      Jun 2006
      Katy,TX
      Reminds me of the old Devo song "Whip It".
      2004 Pulse Red GTO
      Dec 2010
      Fredericksburg, VA.
      Tobin,
      I suspect there a mis-type on this page?
      http://www.kore3.com/proddetail.php?prod=10122
      Specifically, I assume the line kit includes two front lines, two rear lines and a drop line. But that's not what the page lists in the kit.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Oregon
      Quote Originally Posted by TheJDMan View Post
      Tobin,
      Typo...you're correct, it includes (2) fronts, (2) rears and (1) rear center hose and hardware. Thanks for the heads up.
      Tobin
      KORE3
      It's what I does.
      Northwestern NJ
      The makeup of the liners of race braided brake lines vs. DOT is also somewhat different. Race brake lines are considered to have a somewhat limited lifespan & are periodically replaced.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Southern Indiana
      Goodridge sells dot lines I believe
      Lee Abel
      AFTERMARKET PERFORMANCE
