Results 1 to 20 of 30
12-31-2010 #1
LS1 rear discs on a 9" ford with GM ends
I have a brand new big bearing ford 9" housing with GM ends. I will be using LS1 Camaro rear brakes. I set one of the new axle assemblies in. The bearing slides in good. The outer seal looks like it might not seat all the way in the axle tube on the outer edge. Will I need to run a spacer between the backing plate and the housing flange to allow for this? Or should that seal go all the way in? I'm not ready to knock the seal in just yet.
12-31-2010 #2Here are pictures to describe what I'm talking about. It looks like the seal will be sticking out about an eighth of an inch. I've read many posts about spacers being used, just wasn't sure if this was why.
01-01-2011 #3
- Join Date
- Aug 2004
- Location
- Texas
- Posts
- 327
