View Full Version : The LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13
  1. LS1 with a carburetor (33 replies)
  2. Looking for GM part # 12577904 baffle for a 05+ CTS-V oil pan (6 replies)
  3. New to LSX (4 replies)
  4. Fuel line diameter?? (7 replies)
  5. S&P header install questions (3 replies)
  6. Autocar Oil pan clearence (2 replies)
  7. Engine Mounted but have misc problems (7 replies)
  8. Replacing v6 with v8 in 98 Camaro (2 replies)
  9. got some questions about an A body swap (2 replies)
  10. LS1 Fuel System Regulation (6 replies)
  11. LS1 or LS2?? (10 replies)
  12. Oil pressure switch location needed (3 replies)
  13. Hooker LSX Conversion Headers for First Gen F body (18 replies)
  14. Ls or LQ9 or ? Help me move in the right dirrection (0 replies)
  15. LSX LQ9 LQ4 or ? (5 replies)
  16. LQ4/T56 Swap (1 replies)
  17. Manual Ls1 engine with 1995 4L60E, possible? (0 replies)
  18. Priming oil pump??? (8 replies)
  19. LSx cam sync, How does it work? (3 replies)
  20. LS1 and S&P oil Pan (2 replies)
  21. S&P Headers.. What O2 sensors?? (3 replies)
  22. 6.0 in 69 camaro (5 replies)
  23. Have LS1.. Want A/C.. How to do it (1 replies)
  24. A Complete LS1 Re Build ? (15 replies)
  25. LQ9 Cadillac engine upgrades? (6 replies)
  26. LS1 Fuel Tank question (2 replies)
  27. Simple Question* LS1 68 Camaro (4 replies)
  28. Motor mount questions (1 replies)
  29. L76 intake questions (10 replies)
  30. Need help!! 98 LS1 in a 68 Camaro running bad when at temp (8 replies)
  31. ATS oil pan dimensions (7 replies)
  32. how to run the return line? (7 replies)
  33. Throttle by wire pedal (3 replies)
  34. Cruise control (0 replies)
  35. Left vs Right Knock Sensor (1 replies)
  36. Cadillac Escalade Engine/Trans Swap? (4 replies)
  37. Variable Timing With Aftermarket Camshaft (7 replies)
  38. Speartech truck pulley thingy (1 replies)
  39. Need Head bolt length (8 replies)
  40. 68 Camaro with LS1- Looking for cold air intake ideas (20 replies)
  41. LS2 heater hoses (2 replies)
  42. Anybody used Wait4me performance? (15 replies)
  43. Cracked block??? yes or no (8 replies)
  44. f-body clamshell motor mounts (2 replies)
  45. Need LS1 block picture (2 replies)
  46. LSx PCV and Norris catch can (30 replies)
  47. Clutch setup? (5 replies)
  48. ls block power (11 replies)
  49. LS2 engine height (2 replies)
  50. LT1 wiring question (2 replies)
  51. Tank and fuel system options (10 replies)
  52. 700 rwhp Gen1 Camaro help (10 replies)
  53. Aftermarket a/c w/GM-LSx comp = problems? (9 replies)
  54. Anyone know a good way to hook up kickdown for 700r4 to LS1? (5 replies)
  55. How do you get cruise control with cable throttle? (7 replies)
  56. LS7 oil pan adapter (3 replies)
  57. Gas Pedal Mounting w/Shaved Firewall (0 replies)
  58. 5.3 in a 67 f-body (1 replies)
  59. Torque Converter Storage (1 replies)
  60. Bolt size 1st gen LSX swap? (1 replies)
  61. LS AC Compressor Bracket Relocation Kit (3 replies)
  62. ls6 into 67 camaro questions (6 replies)
  63. GP on Edelbrock A Body LSX Headers (1 replies)
  64. Norris Motorsports Is Now A PT Sponsor (3 replies)
  65. Pedal Ordering Questions for 68 maro LS1 (2 replies)
  66. Cant decide which mounts to buy! (13 replies)
  67. hooker HOK-2289-1HKR (1 replies)
  68. LS7 headers (0 replies)
  69. LS1 Starts and 3 seconds later kills power to injectors? (7 replies)
  70. S&P T-56 shifter relocator?? (7 replies)
  71. 5.3? or 6.0? (4 replies)
  72. Tell me about Gauges?? (5 replies)
  73. Professional Parts Typhoon Intake (1 replies)
  74. anybody flipped the ats mounts???... lsx in 70 chevelle (10 replies)
  75. Shredded belt on LS7 (2 replies)
  76. 200r4 mated to an LS engine? (2 replies)
  77. LS Crate Engine Suppliers (7 replies)
  78. Ls2 Harness Ebay (3 replies)
  79. Which Computer? (8 replies)
  80. LT1/t56 vs lsX/t56 dimension questions? (3 replies)
  81. Fuel system questions (4 replies)
  82. LSX FAST XFI,PERFECT CIRCUIT harness (0 replies)
  83. Aluminum or Steel driveshaft?? (16 replies)
  84. Weight of LS1 and T56?? (3 replies)
  85. Painless LS1 conv harness good? (3 replies)
  86. What the heck am I doing wrong? LS1/T56 driveshaft vibes....... (4 replies)
  87. What dia. exaust pipe for LS1? (6 replies)
  88. LS1 has Hooker headers. Will they work in 68? (10 replies)
  89. Will BBC mounts work for LS1 Swap? (3 replies)
  90. help!! have ls2 crate motor won't fit (3 replies)
  91. ls1 intake/pulley on lq9 (1 replies)
  92. LS2 Swap 67 camaro Radiator help (8 replies)
  93. Hooker header size vs SW headers (2 replies)
  94. LS1/T56 1st gen Camaro guys.....I need andvice with a driveshaft issue...... (1 replies)
  95. Popular Hot Rodding LS2 build link (10 replies)
  96. Ls1 in a 65 a-body (3 replies)
  97. ALUMINUM RADIATOR with built in trans cooler (8 replies)
  98. Hooking up factory gauges.... (3 replies)
  99. Dougs 1st Gen Headers and Mounts (0 replies)
  100. AC relocation (1 replies)
  101. Need a wiring schematic for 03-06 ls truck (0 replies)
  102. LS2 Motor mount question (1 replies)
  103. LS quick charging wire ? (2 replies)
  104. Confused and know you guys can help LSx 6L questions (6 replies)
  105. Got me an LS1. (1 replies)
  106. Show off your 1st gen Camaro/LS swap! (13 replies)
  107. LS2 Carbed Engine (7 replies)
  108. Yay! Finally got an LS1! Now I need help, lol. (15 replies)
  109. GM Type 2 power steering pump on LS1? (14 replies)
  110. Any Lq9 N/A builds? (4 replies)
  111. LS-9 in Marine (0 replies)
  112. 68 Camaro LS2 Header install PICS (19 replies)
  113. Car Craft LQ4 article (1 replies)
  114. LSx swap in SoCal (0 replies)
  115. Cold air intake shield (0 replies)
  116. T56 shifter location in 69 Camaro?? (3 replies)
  117. Sorry....ATS Plates with Stainless Works Headers ONLY 69 Camaro (9 replies)
  118. 1972 Olds Convertible 408ci 4L80E Powered (6 replies)
  119. 408 LSx bearing material in oil filter (4 replies)
  120. ls2 t56 in 67 camaro (4 replies)
  121. 69 Camaro T56 shifter options (8 replies)
  122. GM LSX Crate Engine Info???? (1 replies)
  123. LS9 Crate engine? (20 replies)
  124. How many LS serpentine systems available? (38 replies)
  125. 730 hp na LS7 pump gas dyno video (1 replies)
  126. streetrodengines question? (6 replies)
  127. WOW... LS1 conversions keep getting cheaper! (39 replies)
  128. f body oil pan fits 1rst gen without cutting (45 replies)
  129. LS2 Radiator ?? (1 replies)
  130. Where to get intake tubing? (11 replies)
  131. Pace Performance Old School LS2's (19 replies)
  132. ATS T56 hydraulic MC firewall seal. (2 replies)
  133. Cast turbo Manifolds for LSx (10 replies)
  134. 2003-04 5.3 Motor (2 replies)
  135. Transmisson Type (4 replies)
  136. Just bought a lq9! Now how big of cam? (5 replies)
  137. bbc vs lsx car values?? whats better (11 replies)
  138. t56 mpg question 454 bbc vs ls1/ls2 (3 replies)
  139. Looking to clean up the engine bay (3 replies)
  140. 6.0 GM truck motor in 1st gen Camaro??? (3 replies)
  141. ls1 coil on valve cover 45* spark plug wires. (12 replies)
  142. Ls2/tko500 (4 replies)
  143. LS2 camaro dyno results (5 replies)
  144. crate lsx (1 replies)
  145. Ls1 (6 replies)
  146. LQ4 swap in a 68 camaro (29 replies)
  147. Fuel system questions (3 replies)
  148. Edelbrock ls1 headers for chevelle? (2 replies)
  149. LS3 in a 66 chevy II nova (3 replies)
  150. Drive by wire mounting (11 replies)
  151. Pulley issue need help please (7 replies)
  152. Thoughts on dropping in an L92? (18 replies)
  153. I am WAY overwhelmed.... GMPP LSX in a 70 Chevelle (8 replies)
  154. Gas tank setup (6 replies)
  155. Motor mount and engine mount just wont line up (12 replies)
  156. LS1 engine harness (11 replies)
  157. Another LS swap mount plate, real nice from AA (1 replies)
  158. LS2 Swap first-gen Headers Help! (26 replies)
  159. LSx Motors: why switch to a carb intake? (22 replies)
  160. pics of the hooker mounts in a 69 (9 replies)
  161. Freshen' up a 6.0L (6 replies)
  162. Caddilac LQ9 question (15 replies)
  163. What to do about a gas pedal assembly? (37 replies)
  164. Schwartz LS7 projects (2 replies)
  165. Twin Blown lsx by Nre (8 replies)
  166. Ultimate LSx Build (14 replies)
  167. What brand fuel rail covers are these??? (5 replies)
  168. Is this gonna work for the fuel pressure? (3 replies)
  169. 600 hp LSx with 2.5" exhaust? (20 replies)
  170. Transmission Crossmember (2 replies)
  171. LS1 tweaking and durability (9 replies)
  172. so here is my "budget" LS1 combo (14 replies)
  173. Edelbrock is making ls 70-72 A body conversion kits (0 replies)
  174. 4l80e and LS2 Crate Motor Help (4 replies)
  175. s&p plates, ats crossmember, engine isnt level *pics (29 replies)
  176. Hummer oil pan in ls1 camaro (1 replies)
  177. LS1/T56 into a 2ndGen Trans Am: lot of questions (21 replies)
  178. 67 LS1 Camaro (2 replies)
  179. 454 lsx? (4 replies)
  180. Setting up Transmission angle (LS1 related). (13 replies)
  181. LS2 Info ? (1 replies)
  182. ls1 camaro frame mounts (7 replies)
  183. Mast Motorsports LS3 427 Dyno Numbers and Product Release (18 replies)
  184. N00b LS question (13 replies)
  185. 67 Camaro LS1 project (3 replies)
  186. what are the specs on the LS1 master cylinder? (2 replies)
  187. Anyone come out with a new LS front runner? (39 replies)
  188. Professional Products LS1 intake? (16 replies)
  189. power steering pump and bracets for 1st gen (5 replies)
  190. Help getting started (4 replies)
  191. List of PCM items to delete.... (8 replies)
  192. 1st gen ls1 swap with turbo (7 replies)
  193. What is this and do I need it? (6 replies)
  194. ls1 in a 1st gen, what power steering hose? 3rd gen box (4 replies)
  195. Doug's ls1 swap headers!!!! (17 replies)
  196. Venting spent gases in an LS1.... (30 replies)
  197. t56 in a 79z (1 replies)
  198. Question (1 replies)
  199. Still confused on this oil and temp sensor deal..... (43 replies)
  200. I might be buying this LS7 engine.. need help IDing it.. what do you guys think? (11 replies)
  201. Would this fuel pump be good for an LS1? (3 replies)
  202. Stroked h/c/i LS1, LS2 h/c/i, or LS3 c/i????????? (1 replies)
  203. LS motor installation kits (5 replies)
  204. Ls1-t56? (14 replies)
  205. lsx instalation kit for a 72 nova (3 replies)
  206. Friggin need advice (18 replies)
  207. Questions on engine building (3 replies)
  208. 70 Camaro LS1/T56 questions???? (2 replies)
  209. newbie needs help: LS2 or LS1 for 2nd Gen F Body (48 replies)
  210. 4th gen headers on 1st gen? (5 replies)
  211. What body harness in 69 Camaro w/LS1?? (15 replies)
  212. Hard time Choosing.. built LS2 or stock LS7 give me your vote! (49 replies)
  213. Stripped oil pick up tube bolt?? (5 replies)
  214. Stripped bolt on LS1?? (18 replies)
  215. LSx running hot only at idle (15 replies)
  216. ricks efi tank with carb ls1 setup (14 replies)
  217. Questions about running an external fuel pump.... (14 replies)
  218. what are the best mounts for 79z (2 replies)
  219. 2005 6.0 swap in to a 2000 ws6, need some help! asap! (4 replies)
  220. Some helpful LS1/6 etc Info (1 replies)
  221. Considering replacing LS6 with LS7. Can I still use the headers? (10 replies)
  222. To tune or not to tune? (20 replies)
  223. Bored out 5.3L for LS1 pistons? (8 replies)
  224. LS6 intake casting numbers (2 replies)
  225. LS1 swap into a 55 re:exhaust manifolds (0 replies)
  226. Big Problem Please Help?? (6 replies)
  227. What header bolts work best (2 replies)
  228. Gaskets for S&P Headers (2 replies)
  229. oil pressure sender question (17 replies)
  230. LSX porn. Post up your best LSX engine photos. (460 replies)
  231. Anyone done TT LSX setup in 1st gen? (11 replies)
  232. Let's talk gauges (6 replies)
  233. Anyone deal with Dave @ OC Stangs?? (0 replies)
  234. Delima (8 replies)
  235. I have too much fuel pressure (1 replies)
  236. Fuel system questions..... (7 replies)
  237. Are all T56 crossmembers created equal? (2 replies)
  238. questions about ls2 402 (13 replies)
  239. Anyone... (9 replies)
  240. pictures and measurements of Trans Dapt LS1 mounts (0 replies)
  241. LSX coil packs (8 replies)
  242. What year F-body radiator and fans in 69 (3 replies)
  243. ls1 engine install guide pdf file (5 replies)
  244. thoughts on painting an LSx motor... (47 replies)
  245. LS Time - Help me choose... (4 replies)
  246. 6.0 + L92 heads = 500 hp? (10 replies)
  247. Anyone using the trans dapt motor mounts on their 67 camaro (1 replies)
  248. How much boost? (16 replies)
  249. Questions on a LQ4 or LQ9 build (9 replies)
  250. Rear gear in LS1 69 Camaro (15 replies)
