View Full Version : The LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13]
  1. Speed Density or MAF/IAT?
  2. Power steering lines Holley to Chevelle box
  3. DSE subframe using holley engine and trans crossmember
  4. Shop recommendations for a turn-key car???
  5. oil pressure
  6. ECU mounting location
  7. 2nd Gen Camaro +Factory AC + LSX - Fitment issues
  8. Aluminum flakes
  9. 1967 Camaro LS3/6L80e swap kit
  10. E38 ECU question
  11. Connect & Cruise LS7 vs. Aftermarket Build
  12. MAP Question/P0108
  13. Tru Turn with Hooker Blackheart long tubes
  14. LS7/LS9 oil tanks for a 69 Camaro - tips and advice needed
  15. LT4 with 8 or 10 spd trans swap help & questions
  16. Rubber inserts in Holley clamshell mounts
  17. 5.3 vs 6.0
  18. GM discontinues LS7 engine
  19. Low mount AC on 1st Gen Camaro LS2 swap....
  20. Oil pan recommendation?
  21. Stock fuel line to LS fuel rail help
  22. auto-x specific LS engine recommendation?
  23. LS options for a 1966 Tempest
  24. Experience using Speed Engineering Mid-Length in an 1967 -1969 F-body?
  25. L99 to LS3 Conversion
  26. Engine Clearance
  27. Fuel pressure sensor
  28. LS3 consuming lots of oil
  29. LS3/480 convertor stall choices
  30. Connect and Cruise LS430/6L80E
  31. Which LS SWAP OIL PAN?
  32. Flywheel and clutch
  33. Any reason to use LS2 heads on an LS3, or did engine shop really screw up?
  34. LS7 backfire initial startup E39 ecu
  35. Difference between Holley Terminator LS and Terminator X LS?
  36. VVT strokers?
  37. Oil pan for 2nd gen
  38. Remote mount power steering for the LS3 into a 1st Gen Camaro?
  39. LS3 misfire
  40. What's causing fuel imbalance on cylinder banks
  41. II Much VSB Vent in a 69 Camaro stock floor pan location?
  42. 67 camaro ls3 cooling and fuel
  43. 418 Ls3 cranks slow
  44. New guy looking to Identify LS
  45. What replacement LS3 timing chain is the go to?
  46. Whats part number for 58x crank sensor?
  47. Carnage. (was "What can I swap in?")
  48. Running L3 crate without A/C conected?
  49. Terminator X with only one O2 sensor?
  50. Spontaneous Power Loss
  51. Oil pump won't prime
  52. Finding a Rebuildable LS Engine Core
  53. Why am I idling so high?
  54. LS2 questions from a long idle project
  55. P0507 (High Idle) is driving me crazy.
  56. Connect and Cruise start up issue
  57. LS427 exhaust manifold part number?
  58. LS3 swap Holley EFI vs OEM computer
  59. ecm pinout for 2015 z28
  60. V6 LS3 (2 dead holes).
  61. Universal Crank Trigger on LS?
  62. 67 Camaro LS7 E38 ECM Deap Pedal Problems
  63. Fitting the oil pan in a 64-67 GM A-body
  64. LS swap choices
  65. Dbw vs dbc
  66. Charcoal evap canister
  67. LS Swap Battery/Air Intake Location
  68. Mounting LSA Intercooler Pump - 69 Camaro
  69. E67 tune - production vs Connect & Cruise
  70. LS3 Radiator Fan Controller
  71. LS1 Swap Cruise Control Help? DBC
  72. LS3 (376/525) MPG - Real world #'s?
  73. What trrans. x-member? 69 Camaro, DSE Sub, LS3, TKX
  74. Solid Motor Mounts using Hooley Swap Kit?
  75. Anyone have experience with LSX Concepts Accessory Drives?
  76. Production car ECM used with GMPP harness?
  77. Thinking of switching the coolant temp sensor to passenger rear vs drivers front.
  78. 454 LSX Runway Racer
  79. Tune for LS7 in a Chevelle
  80. Catch can routing and hose size
  81. Chevelle Turbo Manifolds
  82. New LS3 long block valley plate question
  83. 1973 Vette with a LY6 Questions.
  84. LS3 intake options buy new or used?
  85. Bolt size cylinder head accessories
  86. Ls2 cam sprocket
  87. Ls3
  88. Computer Mount????
  89. Brian Tooley rocker shaft upgrade.
  90. LS3 Need LS Guru help
  91. 69 Camaro stock cowl hood clearance with LSX376B15 and Magnuson TVS2300
  92. ls3 hot cammed gmpp 495
  93. Do I need a Catch Can
  94. 2002 camaro power PS reservoir with O ring replacement, Where to buy? (not junk)
  95. OBD2 Communication
  96. 5.3 Idles at 2500-3000 RPM
  97. LT4 in a 56 GMC
  98. Lsa boost control selenoid needed, asap
  99. Tach signal 5v (lsa) run 69 Camaro tach
  100. Upping my game with an LSA upgrade, looking for fueling advice
  101. NA LS3 with future plans to supercharge - unsure which accessory drive I need
  102. Overdriving an LS2 Corvette Power Steering Pump with smaller pulley. Cons?
  103. Removing LS from a second gen Camaro
  104. LT4 Rocker arm issues
  105. LS3 416 or built ls3 for boost?
  106. Question about my LS2
  107. Morel lifters 7717 any good
  108. 4150 throttle body or DBW on carbed stle intake?
  109. 408 Build , what top end??
  110. That Blu Balz dry sump oil breather canister
  111. LS7 crankcase venting help needed
  112. 4L60E cooling lines and long tube headers on an LS
  113. CCW crankshafts - Are they worth having?
  114. Best front springs for 1970 A body with Ls swap??
  115. Who is a cam expert here?
  116. Throttle response?
  117. Will ls and 4l80 fit this modified tunnel
  118. Holley 2nd Gen engine mount height
  119. LS swap kit
  120. 70camaro LSA swap
  121. LS Oil Port Adapters
  122. LSA engine camshaft
  123. LSA engine power up
  124. Cam for LS3 and Whipple
  125. Terminator or factory ecu?
  126. plug wires with flowmaster a-body headers
  127. LS power steering pump aluminum tank replacement
  128. Ls3 MAP sensor issue
  129. 69 camaro with console ls t56 with cobra tailshaft vs regular mag shifter location?
  130. 70camaro ls1→LSA swap
  131. LS3 Cruise and Connect Package
  132. 70camaro LSA swap
  133. LS3 Crate Engine Swap
  134. Firebird LS engine placement
  135. 427 LS into 69 Camaro
  136. Oversized valves in 823 ls heads
  137. LS427 engine cover options...
  138. 1967 Nova LS3 upper radiator hose
  139. 1970 Chevelle LSX swap with UMI 4008 mount kit
  140. Engine Cover Dilemma (LS427)
