View Full Version : ls2 t56 in 67 camaro
saunacrank
03-01-2008, 07:38 PM
So I'm putting a ls2 and t56 I got out of an 05 GTO in my camaro. Suggestions for headers, trans install kit, ect.? Budget in mind cus I'm 21 and still in school full time
Spiffav8
03-02-2008, 09:31 AM
Call Tyler at ATS. He's really good about this stuff and always willing to give advice.
63chevyll
03-03-2008, 05:04 PM
Do you want sell the oil pan?
saunacrank
03-03-2008, 06:34 PM
sure
Shawn MacAnanny
04-05-2008, 12:51 PM
Asside from the car engine and trans here is what it has cost me
Hooker LT headers, ceramic coated great deal on them, $550
ATS plates - $125
two SBC polyurethane mounts - $60
Modified stock TH400 cross member - Free
manual steering box - $90
moroso 7qt pan made for 67-69 swap - $310 with pick up tube
remote mount filter for pan with AN lines and fittings - about $150
LPE high volume oil pump - $90
LT1 radiator with fans - Free and LS1 hoses fit perfect (from parts car i had)
t56kit.com bracket for clutch master cylinder - $90
manual pedal kit - $70
clutch slave cylinder - $90
shortening clutch master pushrod to fit pedals ($90 from a member) or free from me cutting and welding it.
All new gauges and senders dont forget.
There are ALOT of little things you are going to find you need too.
oil pan gasket - $54
timing cover gasket/WP - $43
intake gaskets (if you removed) - $33
There are alot extras too i'm sure i am forgetting. You can IM me @ ShawnMacAnanny if you have any questions throughout your swap. I've had just about everything go wrong so feel free to ask. I did a carb swap though so i'm not entirely sure about the efi setup although i did alot of research on it before selling off my EFI stuff.
