View Full Version : GM Type 2 power steering pump on LS1?
CamaroJesse
03-17-2008, 04:24 PM
Im picking up an ls1 this week and I allready have a gm type 2 pump. Can i get this pump to fit on this motor?
thanks
Jesse
TitoJones
03-17-2008, 04:58 PM
Yep. They come with Type II pumps from the factory.
tYLER
CamaroJesse
03-17-2008, 05:35 PM
Great thanks!
What accessory drive system are you using? You may have to bend the intake tube on the pump if you are using the C5 vette set up. Should not be an issues though if you are careful.
CamaroJesse
03-18-2008, 12:02 PM
I have no idea what accesory drive im going with yet. Id like to go with whatever is cheapest. Im on a budget. As always.
truck is cheapest because it may not work. Fbody is next with the vette bracketry being the most expensive. The truck uses an pump and resevoir integrated design. The reservoir is mounted on top of the pump with the Fbody and the vette is remote
CamaroJesse
03-22-2008, 06:52 AM
Hmm. Yeah im not sure which one yet. I have plenty of time to think about it while I save up for everything i need.
thanks
CarlC
03-22-2008, 07:03 AM
Are the trucks Type 2 (TC or CB) or P-pump? My 5.3 truck is P-pump, and fitting a Type 2 would be difficult.
subtlez28
03-22-2008, 11:03 AM
Anyone have a link to diagrams or pictures of the truck acc. drive set up?
Same question for the different pump types? (sorry newbie to the swap game)
I need to figure out my drive system aswell. I am hoping to keep truck style. I've read its relatively easy to hook up to the old steering box, and I want to keep the truck water pump (my L92 has the VVT)
I just know the 4.8, 5.3, and the LQ truck motors used the P-pump as you call it Carl. This is the more traditional style with the pump actually submerged inside a reservoir. I have no idea about the Gen 4 truck motors.
LQ 9
http://www.gmhorsepower.com/images/LQ9_6_Liter_NoECM_NoHarness.jpg
another
http://www.maserati-alfieri.co.uk/enthusiast66/GM-northstar-a.jpg
C5 corvette LS
http://images.chevyhiperformance.com/thehistoryof/0605ch_17_chevy_ls1_motor_z.jpg
FBody LS1
http://www.myfirehawk.ca/Interesting%20Pics/20025_44.jpg
CamaroJesse
03-23-2008, 10:40 AM
i like the look of the f body one the best. Is this one do-able on a stock frame 68 camaro?
check the sticky at the top of this forum for known swap combos. I believe your answer may be there. If not, someone will chime in I am sure. I personally don't know.
CarlC
03-23-2008, 08:07 PM
Yes, it's one of the most popular.
I'm in the middle of one now.
