View Full Version : S&P Headers.. What O2 sensors??
skeeters65
07-08-2008, 12:48 PM
What O2 sensors are you guys running with your S&P headers??
I heard somthing about Corvette O2 sensors cause the harness is longer..
Need a good answer, dont want to buy more than one set..
dhutton
07-08-2008, 12:53 PM
I used Bosch rear O2 sensors for an 02 Corvette. Plenty long, lots of extra cable to hide. The rear ones are the long ones. Work fine and cost considerably less than the Delco ones. My headers aren't S&P but they are LT's. My engine is an LS1 from a 4th gen F body.
Don
Midnight68
07-08-2008, 02:40 PM
I believe you should use the ones for your motor and ecm. I know the plugs on some are different. My 05 LS2 the rear O2's are different from the front ones. You can also buy harness extensions if you need to.
It's easiest to use O2 sensors from the application the PCM originally came from simply so you don't have to worry about swapping the plugs out. However, they all work the same way so if you can change plugs and don't mind it, go for whatever works best for you. 97-03 C5 Corvette rear O2s have the longest extensions I know of and were Bosch still. 04 Vettes went to Denso.
