View Full Version : LSx PCV and Norris catch can
parsonsj
06-01-2008, 08:09 AM
I just got back from my test drive after removing my hot rod billet valve covers, racing PCV, and K&N breather on II Much (427 LS2). I replaced all that with factory valve covers, factory PCV, and a Norris catch can (http://mikenorrismotorsports.com/Billet_PCV_Catch_Cans.html). I plumbed the passenger valve cover to pull in fresh filtered air from the engine air cleaner through a one-way check valve so oil doesn't go the other way into the engine.
The old setup dumped a lot of oil into the intake tract (the car would blow smoke during decel... particularly on the track). The old PCV setup was sitting right on top of the #7 exhaust rocker arm, so it was getting a lot if oil mist, with no baffling.
The factory setup is fully baffled, with holes drilled between the rocker arms to reduce oil mist.
Anyway, I couldn't be more pleased. I can feel vacuum at the intake port to the PCV system inside the air cleaner, and the catch can was absolutely clean. I even think the factory covers look better, but maybe I'm just excited to have fixed a problem.
Anyway, here's another nod to factory parts for street use. Those engineers at GM do know a thing or two.
jp
oestek
06-01-2008, 08:51 AM
How about some pics, John?
Thanks!
- KO
CarlC
06-01-2008, 09:38 AM
I hear ya John. I too am going with a lot of OE derived parts.
Case in point, I'm going to use the Mann-Hummel Provent 200 catch can. Pics and descriptions here http://www.emotors.ca/articles/128.aspx I don't exactly did the guy's hose type, elbows, etc.
The Mann-Hummel homepage is not working for some reason today, but they have a good description as well.
It's a very nicely designed part. Very OE in appearance and functionality. I've buffed off the barb on the inlet/outlet and made delrin bungs that will epoxy in place. A steel tube with a rolled bead on the end will press into the delrin bung an allow slip-fit hose attachment.
It has a return line that can be plumbed into the oil pan. If below the oil level then no check valve is needed.
andrewb70
06-02-2008, 07:05 PM
The valley cover on my L92 doesn't even have a breather tube.
parsonsj
06-02-2008, 07:15 PM
Andrew, do your valve covers have an inlet port on one side and a PCV on the other?
Kevin, sorry. I'll get some pix up.
jp
parsonsj
06-02-2008, 07:23 PM
And Carl, that's one cool setup with the German kit. Sweat some AN fittings and go for it. Post some photos of how it turns out.
It has a return line that can be plumbed into the oil pan. If below the oil level then no check valve is needed.Wow, what a great idea. I wonder if I could do that. No drainage necessary. I'd need a check valve though.
jp
andrewb70
06-02-2008, 07:26 PM
jp
The driver's side valve cover has a nipple, as does the passenger side. Neither are hooked up at the moment. So is the driver's side an inlet?
parsonsj
06-02-2008, 07:39 PM
One is a fresh air inlet, and the other should go to a PCV and on to the intake manifold.
The idea is to allow clean air into the crankcase to allow crankcase vapors to be evacuated via engine vacuum. I've been told the PCV setups are one of the main reason for increased engine life in later model cars.
jp
andrewb70
06-02-2008, 07:54 PM
So does the driver's side air inlet need filtered air?
parsonsj
06-02-2008, 08:01 PM
On mine, the passenger side is the inlet. You'll need to pull the covers to be sure which is which. And yes, you should use filtered air.
jp
andrewb70
06-02-2008, 08:12 PM
jp
How do you tell?
parsonsj
06-02-2008, 09:09 PM
The inlet is a double plastic baffle, all contained in a 1" vertical mount inside the valve cover. The outlet is a long horizontal baffle that goes most of the length of the inside of the valve cover.
Perhaps you ended up with two inlets??
jp
andrewb70
06-02-2008, 09:11 PM
jp
I remember what you are describing. My driver's side is the intake and the other one is the vent.
tom_a
06-02-2008, 10:07 PM
I think I also will go back to factory covers. I went and looked in the garage at my OE covers. John I am still not sure which is outlet etc. I may be confused, but if you look at picture both the PS and DS rocker covers have baffles?
https://static1.pt-content.com/images/pt/2008/06/900RC1-1.jpg
Here is top which I believe is similar to what Andrew was explaining.
https://static1.pt-content.com/images/pt/2008/06/900RC-1.jpg
Also, my engine does have the fitting in valley cover. Not the best shot but you get the idea.
https://static1.pt-content.com/images/pt/2008/06/900rc4-1.jpg
Not meaning to hi jack this thread just trying to understand before I go and buy one of these catch cans
andrewb70
06-02-2008, 10:34 PM
My valve covers are just like Toms.
CarlC
06-02-2008, 11:43 PM
Mann-Hummell has a check valve available. It's something like $15 through one of the Porsche sites. My friend and I both bought the same setups and paid $150 including shipping for each complete setup.
No joy on sweating on AN stuff. It's oddball diameter due to metric sizing, and it's all plastic so trying to attach anything that will apply torque will likely not hold up well. The thing is super light.
parsonsj
06-03-2008, 04:31 AM
Andrew, you and Tom have "LS6" style valve covers. The PCV outlet is designed to go from the valley cover. The fresh air inlet is the nipple on the cover with the fill port. Leave what is the old PCV port on the other valve cover alone... and use your valley cover instead.
Legend on LS1Tech has it that the LS6 style is better at keeping oil in the engine, but most of the hardcore racers use a catch can anyway.
jp
andrewb70
06-03-2008, 07:08 AM
My valley cover doesn't have a PCV hose, like Tom's engine does. Tom has an LS3, mine started life as the L92 truck engine.
parsonsj
06-03-2008, 07:16 AM
uh... I dunno. I'd bet that you need to use the other valve cover as the PCV source. Maybe Mike Norris will chime in...
Or: any chance you could pick up an LS6 valley cover?
jp
Mike Norris
06-05-2008, 03:13 AM
Hey All,
As John mentioned the passenger side is the fresh air inlet and you can use the blocked off nipple at the rear for to the catch can then the PCV valve and then to the intake port. When doing this remember that the nipple on the passenger side needs to be opened to fresh air, preferably after the MAF sensor if equipped, otherwise a big vacuum will be put into the crankcase and cause more issues.
You may also want to check your tune if it was done with no PCV originally and now adding one as now there is a possibility of it running slightly leaner depending on the install.
Hope this helps. Thanks John!!
Mike Norris
parsonsj
06-13-2008, 05:26 AM
Here's a photo of Mike's catch can as installed.
Rick Dorion
06-13-2008, 06:36 AM
Nice, John.
I'm waiting on the production run to get one too for my sbc. Does yours get piped back into the pan or do you need to drain it?
Thanks!
parsonsj
06-13-2008, 06:45 AM
No, I have to drain it. If you look closely, you can see the aluminum hard line coming out from the bottom. That goes to a ball valve located behind the front air dam. Drainage should be a 2 minute operation.
I have to say that after 20 minutes drive time, I have zero oil in the catch can. Now that I've got my fuel lines fixed, I'll go on some longer drives and report back.
jp
Mike Norris
06-17-2008, 05:37 PM
The can looks good there John and being that it is lower then the intake and no dips in the lines will help contain any oil for sure. The drain is very cool for sure.
I am also attaching a picture of the same catch can being used as a coolant overflow on Scotts camaro from Lateral G.
Mike Norris
slowcamaro
06-20-2008, 01:40 PM
How does one select the correct pcv valve for the application. I was taught that they aren't interchangable due to them being based on engine size and vacuum. How does one select the proper pcv valve for say a low vacuum application?
Shawn MacAnanny
07-09-2008, 04:40 PM
I just got my catch can a couple days ago. I got it shipped here in about 3 days from the day i placed the order and Mike was extremely nice and helpful to me on the phone about getting my PCV system setup. The catch can looks amazing in person too. Very well made. Thanks Mike!
Rick Dorion
07-10-2008, 03:27 AM
Me too.
John, where did you get the ball valve?
parsonsj
07-10-2008, 04:41 AM
I got the valve at McMaster. Search for pn 7775K52. I modified it (cut the spring, removed O-ring) to allow easier air movement.
jp
Rick Dorion
07-10-2008, 05:48 AM
Thanks, John. I'll use that when I run a return to my oil pan this winter. When you said ball valve, I was thinking of some kind of spigot to do my draining easily!
parsonsj
07-10-2008, 08:22 AM
Oh, wait.
I gave you the part number for the check valve between the air filter and the intake side of the PCV system.
For a ball valve, I used an Earl's part. Here's a link at Summit:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EAR%2D230502ERL&N=700+115&autoview=sku
jp
subtlez28
07-10-2008, 10:01 PM
Forgive my ignorance...
Was this a bigger issue on 97-00 LS1s than later versions?
My 02 Camaro has the LS6 style intake (and I ' guessing LS6 style valve covers and PCV system). I've never had a problem w/ oil in the intake, this thing doesn't use any oil despite the road course beatings I give it.
Am I just lucky (for the lack of oil use), or is it just due to later year design?
I just picked up a C4 with a 98 LS1, and wonder if changing to LS6 top end will solve these issues. It will be a more track oriented car.
