View Full Version : LS1 with a carburetor
bradf74
08-11-2008, 02:05 PM
I know it is probably a good way to get me killed around here, but I was wondering if you could get an intake to put a carburator on a 98 vette LS1. I have come across a motor (mostly complete, with harness and computer) and I am kind of scared of the rats nest of wires. If I can't convert it, I will most likley sell it. Can you put a carb on this motor?
oestek
08-11-2008, 02:16 PM
Sure - the Edelbrock manifold leaps to mind as a simple way to adapt... you can use the Edelbrock / MSD ignition control and you're on your way.
But the wires really aren't that scary when you get into it..
parsonsj
08-11-2008, 02:18 PM
Or GMPP makes a complete kit: carb intake, fuel pump, and distributor.
Just like the old days.
jp
1badchevelle
08-11-2008, 02:21 PM
Painless wire also has a really no brainer set up.
bradf74
08-11-2008, 02:54 PM
AHHH the good old days. If I don't sell it I will lookl into the gmpp set up.
WS6
08-11-2008, 05:26 PM
don't be afraid of the wires for running EFI, it's not that bad really. The tunning is more of a problem but just leave that to a professional and you're done.
carb works perfectly fine though. If that's what you prefer, you'll still get the benefits of it being an LSx.
1badchevelle
08-11-2008, 07:55 PM
If you will sell PM me.
Shawn MacAnanny
08-16-2008, 02:05 PM
Works great! You wouldnt believe how smooth running a carbed/cammed LS1 runs. I have a pretty big cam and it idles relitively smooth in general and revs perfect and cruises just like efi. Once you get your carb setup right its easy to tune with the MSD box.
bradf74
08-17-2008, 04:30 PM
Did it cost an outrageous amount to do the conversion?
Shawn MacAnanny
08-17-2008, 05:11 PM
My carburetor i rebuilt and setup was about $300 including the 50cc acclerater pump. (72 primaries, 76 secondaries, 6.5pv)
Holley 97gph pump $100 or so
victor jr intake - $300
MSD ignition box - $320
And thats all you really need.... optional things i have are
Map sensor and connector - $40 (for part throttle timing advance)
Fast dual Wideband O2 system - $420
JYD
08-24-2008, 07:34 AM
very easy, cost about the same as using fuel injection though if you're starting from scratch.
Zee
08-24-2008, 08:57 AM
BS it does. To do EFI right, you would need to add a fuel tank with baffles, return line, modify the pick up and do a fair amount of wiring to mount the computer etc. You would also need to fab up a CAI/filter/MAF combo. Thats assuming he got a working computer and MAF with the motor. Adding the price of a custom tune into the mix, the cost is not even close.
CruizinKev
07-13-2010, 11:28 AM
sorry I know it's a old thread. I'll get a LS1 for my 79 G-Body (monte carlo) soon, also want a T56 anytime later.
I want to run a carb with it because it seems to be easier for me with all the fuel system. I also more like the "classic" carb & air-cleaner look :twothumbs for my car.
but I don't know what I should get for my engine? what do you guys think about the Edelbrock Performer LS1 Intake Manifold Kit #7118 (http://www.summitracing.com/parts/EDL-7118/)?
I know that ignition box that comes with the kit only got 6 different timing curves (means no adjusting the box) but maybe that's good for my needs? and which carb do you suggest for that kit?
hifi875
07-13-2010, 07:43 PM
get the msd 6010 it has better pills and it is computer tunable. you can add a map sensor to it for partial throttle timing advance. the edelbrock kit isn't computer tunable.
96t/acj
07-16-2010, 12:10 PM
^^^ agred and a 650 carb will do fine :) ask me how i know :)
hifi875
07-16-2010, 01:20 PM
i am running a avenger 670 in mine it does just fine
JamesJ
07-16-2010, 01:46 PM
If I was to do my motor setup all over I would just get a LS with a carb adnd be done with it, keep it simple so its on the road more :)
3pedals
07-22-2010, 04:39 PM
I run a 850 mighty demon/ vic jr, and msd 6012 with my stock long block 6.0 LY6. runs awesome, and the 850 mighty demon is jetted almost perfect out of the box.
lowfat69
07-22-2010, 10:52 PM
Anybody build an old school style carb LS motor - you know high comp, high lift rumpity rump cam, how's it sound and more importantly run.
CruizinKev
08-25-2010, 08:09 AM
with a carb/intake + MSD box and its wiring I still need this for my t56 swap into my 1979 Monte Carlo?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360119483663
neki67
08-25-2010, 10:02 AM
Kevin,
you don't necessarily need it. However it provides you with the proper (weathertight) plugs and wiring so you can pick up the (VSS) signal for the speedo and depending on what you want it also allows you to wire in backup lamps, and reverse lockout. I've only used the wiring for VSS signal. Don't have back up lights (yet) on my camaro and the reverse lock out just needs a bit of power to overcome the spring pressure (no harm).
CruizinKev
08-26-2010, 12:28 PM
okay thanks René!
now what fuel pump I need for the carb'd LS1? I heard Holley Blue is very loud/too loud?
neki67
08-26-2010, 01:46 PM
Shawn (see first page) apparently uses this: http://www.summitracing.com/parts/HLY-12-801-1/
According to Holley a Fuel Pressure regulator is not required (for most applications). I think Shawn can answer that one and should also be able to tell you how loud it is.
hifi875
08-26-2010, 05:54 PM
i have a holley black one on mine, very quiet
DCx
08-31-2010, 11:25 PM
i have an edelbrock street 120gph pump and its pretty quiet. you should check out my carbed ls1 build thread. i just replaced the transmission in it yesterday so i will post videos of it running.
https://www.pro-touring.com/forum/showthread.php?t=37078
CruizinKev
09-01-2010, 11:39 AM
cool can't wait! :cheers:
NOPANTS-68
09-01-2010, 01:00 PM
I LOVE my carb'd LS1. Here's mine running:
w0dL_VBNqEI
67CamNKC
10-18-2010, 06:42 PM
How is the fuel mileage on your carb setups? Anywhere close to EFI?
osdmike
10-19-2010, 11:21 AM
Yes! I´m curious too.
Is it possible to get a decent mpg with carb setup,when You go on the Highway?
hifi875
10-19-2010, 11:28 AM
so far the best ive gotten w/my 5.3 is 21, but that was b/4 i got map sensor hooked up. and was running on one of the msd pills.
bullitt4110
11-10-2010, 12:09 AM
Cant wait to get mine running! I have the Edlebrock Vic Jr and the MSD 6010 box.
Raad
03-25-2014, 03:30 AM
I hope i get an answer on this old thread.
I need help with the edelbrock timing control made by msd , the box that comes with the 7118 kit.
Timing seems way off ! Loud knocking when flooring . Contacted MSD and Edelbrock both gave me tge run around . So am looking at the forums for help.
Stock lq4 (6.0L)
Edelbrock 750 carb
Edelbrock 7118 kit
Holley blue pump
Mallory regulator set to 6 psi
Mechanics said its the timing ! Edelbrock said no way go back to a mechanic and change the carb needle?
Msd said call edelbrock we made to their specs!
Lots of threads about timing being too advanced on the box ! I cannot figure it out
Any help is appreciated
hifi875
03-25-2014, 06:28 AM
have you tried all of the chips. and is 6lbs enough? I didn't run a regulator when I had my carb setup. Now ive switched to the Holley Terminator EFI setup, but I never had any knocking. If you have a bog, or stumble, then you need to up your accelerator pump from a std 30cc to 50cc. I had to do that initially with my setup.
Derek@ModernSpeed
04-01-2014, 05:55 AM
For those that may do a carb conversion on LS1/LS6 or LS3 engines, Holley has a mid rise, single plane 4150 flanged manifold. Pretty good looking piece of hardware. They are also available for multiport configurations.
