View Full Version : Caddilac LQ9 question
orang-kr8
12-13-2007, 08:03 PM
I found a 2004 6.0L lq9 cadillac escalade motor for sale on craigslist for a reasonable price, but I cant seem to find any info on the throttle type. Is it drive by wire or cable actuated?
fast400
12-14-2007, 01:25 AM
It's a drive by wire...make sure to get the pedal and module.
Posi12Bolt
12-14-2007, 01:43 AM
or change the TB to a cable type
PT Goat
12-14-2007, 09:07 AM
My LQ9 Silverado was drive-by-wire.
orang-kr8
12-14-2007, 04:21 PM
Any problems with converting from D.B.W to throttle cable? (wiring,ecm,etc...) Thanks for everybodys help :worship:
cDuck28Z
12-19-2007, 01:32 PM
What kind of Tranny are you gunna put behind this bad boy?
No problems with converting to cable from DBW. Just be sure to have the PCM tuned accordingly. If you're having someone else do the harness, make sure they know of the change as well.
Samckitt
12-19-2007, 09:12 PM
What year was your Silverado that had the LQ9?
DarkoNova
12-19-2007, 10:39 PM
Pretty sure Silverado's never came with LQ9's.
Matt
Project69
12-19-2007, 11:14 PM
Matt
The 03-05 Silverado SS did, the LQ9 is just the High output vortec 6.0L, and what ever had the vortec max option came with the LQ9 motor.
Samckitt
12-20-2007, 05:41 AM
Ah I see said the blind man. Mine has the LQ4, what is the difference between the two?
PT Goat
12-20-2007, 06:46 AM
It has been covered above, but since you asked I had an '03 Silverado SS. As others have noted, the LQ9 came in the SS and eventually the Vortec Max. It was premium only (higher compression), while the LQ4 was okay with 87. Pretty sure the HP was 345 vs. 300.
Samckitt
12-20-2007, 07:04 AM
Are the heads, cam same/different?
rocketman
12-20-2007, 01:13 PM
same heads different cam I believe, My Vortec max Silverado has the LQ9 in it
pistons and rods where different in the 9's. That's how they increased compression versus using a smaller cc head. The rods are just stronger but the same length between the two.
orang-kr8
12-25-2007, 12:41 AM
The all mighty t56....if I can find one!
