View Full Version : 69 Camaro T56 shifter options
skeeters65
02-29-2008, 07:21 AM
What are my options for a shifter on a LS1 T56 setup in a 69 Camaro?? Stock center counsol..
Nine Ball
02-29-2008, 08:56 AM
Pro 5.0, Hurst Billet, B&M are the three most popular.
mightymouse713
02-29-2008, 10:21 AM
I am wondering the same thing....I thought that the center console would have to move back quite a bit. I am doing a LS1/T56 in my 68 with console/gages and would like to keep that stock look if at all possible.
CamaroLance
02-29-2008, 10:49 AM
Contact Street & Performance ( http://www.hotrodlane.cc/ ). I'm pretty sure they have a shifter relocation kit that moves the shifter up like 3" or so.
Don't know if there are other options...
derekf
02-29-2008, 10:59 AM
Beware if you have a B&M. They've got a "lifetime warranty".. but if you don't have the receipt, you're SOL.
The plastic ball in my B&M shifter in my 98 crumbled, and they're not willing to do anything about it since I've got no receipt.
t/a-speedfreak
04-13-2008, 04:19 PM
Tony, Do these companies offer shifters that have an offset to keep the factory 4 sp location?
skeeters65
04-13-2008, 05:13 PM
S&P makes one that you can use a stock senter counsol..
t/a-speedfreak
04-14-2008, 06:11 PM
So this is the only option? I assume it is but I thought maybe the others offered something as well.
ErikLS2
04-15-2008, 07:05 AM
I felt one of these MGW Shifters in a Mustang with a T-56 and it was unbelieveable. I believe most T-56 tail housings have the same shifter bolt pattern in which case it should bolt on plus you can rotate the shifter 360 deg around. I've e-mailed them and they don't know if it will fit on a non-mustang T-56, but if you can match up the bolt patterns it should work and it feels awesome like I said. The owner of the Mustang it was in did A LOT of research and loves it too. Here's the link:
http://www.mgwltd.com/mustang_shifter.shtml
