View Full Version : Aluminum or Steel driveshaft??
skeeters65
04-14-2008, 08:03 AM
What are you guys using with your LS1, T56 first generation Camaros??
I ahve the stock aluminum driveshaft out of the donor 2002 Camaro.. Can it be shortened or should I have a new steel one built?
What HP will the aluminum handle?
Mike Holleman
04-14-2008, 09:07 AM
I'm building an LS2/T56 powered 65 El Camino. The Ls2 will have an extra 100 plus HP. Denny's built my driveshaft. 3.5 inch aluminum. I have used his shafts on several builds without any failures. He guarantees them for life against weld or tube failure. He will use steel or aluminum. I tell him what I have and how it will be used and accept his judgement as to what I need.
Mike Holleman
redhead
04-14-2008, 11:33 AM
I don't first hand experience with the fitment but I have considered
this for my first gen also.
since the alum shaft requires extra girth (its fat) for strength I see
spacing running out in the tunnel if you are running large dual
pipes.
da.
Shawn MacAnanny
04-15-2008, 03:22 PM
Im pretty sure the 4th gen driveshaft is too short (i think or i measured wrong). I'm having my stocker cut and rewelded for now and i'll be having dennys do a steel driveshaft for me. I dont see saving 20lbs or so justifiable for double the cost.
HotRod68Camaro
04-17-2008, 02:56 PM
I have a Denny's 3" steel nitrous ready driveshaft. Unless you are doing some 8s passes a 3.5" aluminum one should be fine if its built right (i wouldn't trust a stock one). Here is a thread from LS1Tech on the subject.
http://www.ls1tech.com/forums/showthread.php?t=622609&highlight=driveshaft
Shawn MacAnanny
04-17-2008, 03:11 PM
How much was your dennys driveshaft?
cheapthrillz
04-17-2008, 03:30 PM
You also have to remember that the extra money spent is going towards more hp and tq to the wheels at lower RPMs and launches. A lighter driveshaft (wheels, axles, etc) will improve your driveline efficiency. Just a thought. It might be twice the cost but it is sheding pounds and increasing hp and tq to the wheels...
nicks67camaro
04-17-2008, 03:45 PM
I see your in CT If you decide to have one built one I've had 2 built by Levine's automotive in danbury good price and and never had an issue.
skeeters65
04-17-2008, 04:19 PM
Nick,
What did they charge for an aluminum shaft??
nicks67camaro
04-17-2008, 04:25 PM
the first service I have a 3 inch dia. (steel) drive shaft made for around $260 (its been a while). The second service (recently) I had was to have the drive shaft shortened for $65. My friend was trying to do some really creative stuff with his drive shaft (new 350z motor/tranny in a 91 240) and they were willing to listen and offer a solution for him. Give them a call and feel them out.
HotRod68Camaro
04-17-2008, 06:39 PM
I can't recall and i don't have my reciepts handy.
jasonsnova
04-18-2008, 08:03 AM
dido on the dennys great company! i had a nitrous ready built for my nova, it wasnt that much ....$300..something i think, but it is lifetime warrenty, and last year i switched from a th350 to a t56 speed and they shortened it for free and had a super fast turn arond time. also the nitrous ready shaft really isnt heavy it was about the same as my stock one...
monza
04-18-2008, 08:29 AM
There is always carbon as a option....
trapin
04-18-2008, 08:40 AM
I had a new steel one made at DTS for around $250. Money well spent to just have a new one made.
skeeters65
04-18-2008, 12:41 PM
What does that thing weigh and what did you pay for it??
John McIntire
04-18-2008, 12:48 PM
another vote here for denny's. I have a HD aluminum driveshaft from them. It worked fine behind a 500HP SBC. I have yet to try it behind the 572 yet. I sent it back thinking it needed to be shortened for the new BBC, TKO600 setup, but it actually was about 3/8 inch short. All he wound up doing was changing out the yoke for me to fit the trans. He said I should be alright with it and I might notice a slight vibration on deceleration, but then again with a 572, solid motormounts and 3" exhaust I probably won't even notice.
Great company, and excellent turnaround!
HILROD
04-18-2008, 02:12 PM
I had a 3 inch aluminum driveshaft on my Camaro till I took it to the track. The third or forth run, it was on the track. Now it has a steel Denny's shaft.:hammer:
