View Full Version : The LSX Forum
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. LSx Under Drive Pulley....Benefits out weigh the risk? (10 replies)
  2. ls swap with stock f-body oil pan? (1 replies)
  3. Question about finding a vendor (4 replies)
  4. Questions Before 1st time Fire on LS (9 replies)
  5. Need o2 help (2 replies)
  6. Need help: LS swap options (40 replies)
  7. Lq4 with 4l80e question (3 replies)
  8. Ls3's. Hot or Not? (7 replies)
  9. 67 chevelle with 2012 ls and 6 speed auto swap (5 replies)
  10. Fuel tank suggestions (9 replies)
  11. Is it worth it or not? (5 replies)
  12. Big LS power inside!! (7 replies)
  13. oil pan options (2 replies)
  14. Wich way do I go? (3 replies)
  15. Driveline angle of LS installed in a 69 Camaro (17 replies)
  16. Mast Motorsports 427 v. Katech? (4 replies)
  17. What oil pan to use for LS-1 into 1969 Firebird w/ original sub frame ? (7 replies)
  18. th400 to 5.3 (5 replies)
  19. Ideal motor mount position/type lsx swap? (4 replies)
  20. 660 RWHP N/A H/C/I pump gas LS7 Monte Carlo SS update, now 680 RWHP! (22 replies)
  21. Proper power circuits for ECM? (5 replies)
  22. I know the question has been asked in the past but Camaro ECM mount under dash pics? (3 replies)
  23. Olds 455 or low mileage LS1? opinions (27 replies)
  24. LS3 fuel line routing question on a 69 camaro... (6 replies)
  25. Would a defective 411 PCM throw a code? (7 replies)
  26. Anyone have a CTS-V oil pickup tube laying around? PN 12621299 (0 replies)
  27. Can anyone recommend the BRP LS conversion kit for a 69 camaro? (2 replies)
  28. few questions ls1 into an 88 monte carlo ss (3 replies)
  29. What Lifters should I upgrade to? (5 replies)
  30. Connect & Cruise accessories question... (0 replies)
  31. Texas Speed Contact (2 replies)
  32. ls1 swap open headers smoke **help** (20 replies)
  33. Anyone looking for a MAST oil pan? (7 replies)
  34. LXS454 - Codes -P0068, P0101, P1101. Wiring, Tune or Sensors (0 replies)
  35. +- 7000$ - crate LS3 or build engine...must pass some emission test...goal 450whp (4 replies)
  36. What gauges work for 5.3 swap?! (1 replies)
  37. Recommended radiator for ls3/up to 600hp (6 replies)
  38. AC Compresser notch panel (5 replies)
  39. vaporworx tank no pressure (10 replies)
  40. 2005 Silverado donor truck for my 68 camaro questions? (3 replies)
  41. Position Available for Full-Time Salesperson at Texas Speed & Performance (2 replies)
  42. LS3 misfire ,breaking up, from 2500 rpm to 3800 rpm (0 replies)
  43. Delphi ECU mounting ideas (4 replies)
  44. Holley Hi-Ram intake on camaro (9 replies)
  45. LS3 in my 71 Camaro motor mount question (8 replies)
  46. LS7 & DSE Subframe - what wet sump to use ? (2 replies)
  47. LS Conversion Parts Problems (9 replies)
  48. Engine Seized - Now What??? (9 replies)
  49. Where to get an LS-3 (54 replies)
  50. carb'd LSx intake question (5 replies)
  51. 67 ls swap radiator hoses part # needed and MAF (10 replies)
  52. Has any one used this package? (0 replies)
  53. LS3 480 HP... T56 Magnum 3200 # car (11 replies)
  54. Anyone in need of some custom grind Cam shafts? (0 replies)
  55. Question on tranny out of 02 C5. (3 replies)
  56. is there a list? (20 replies)
  57. Twist machine adjustable shifter (1 replies)
  58. Any chance these headers would fit---first gen (1 replies)
  59. LS swap question? (6 replies)
  60. Carb intake trade? (0 replies)
  61. spal fan sensor (4 replies)
  62. Emissions Question (1 replies)
  63. carbed ls coil mount (7 replies)
  64. bigger injectors, do I need a tune?! (5 replies)
  65. Edelbrock Coil Covers - Would they fit on a LS3 6.2? (4 replies)
  66. Fuel Line from the Tank to the Fuel Rail (21 replies)
  67. need some comp cam help from the cam gurus (4 replies)
  68. LS2 in 72 Chevelle Questions [URGENT] (9 replies)
  69. Harness question (8 replies)
  70. I need Tuning Help. Somebody has to know... (41 replies)
  71. Which is better? Short deck or tall Deck block (6 replies)
  72. Just bought a 68 Camaro (3 replies)
  73. Confirmed! Swap mounts and oil pan clearance (3 replies)
  74. Lets see the carbed ls conversions (11 replies)
  75. Ricks tank with Vaporwox controler (6 replies)
  76. LS1 Sensor Question (what is it) (2 replies)
  77. LS engine install book advice (2 replies)
  78. GTO LS2 into '69 Camaro question (5 replies)
  79. C5 ls accessory drive with DSE steering rack and Hydratech hydroboost (3 replies)
  80. LS2 and Corvette Pedal won't communicate (9 replies)
  81. 1968-73 Nova / LS3 Accessory drive (2 replies)
  82. Fast 92mm (4 replies)
  83. Blue Print Engine LS3 427 (12 replies)
  84. Aftermarket Launch Controller (0 replies)
  85. LS Conversion headers for first gen F-Bodys (new header being developed) (14 replies)
  86. ls monte carlo (6 replies)
  87. Dingo Sliders for LS mount in 69 camaro (17 replies)
  88. steering (0 replies)
  89. Wanted: Truck LQ4 intake (12 replies)
  90. 67-69 Camaro gas tank or other tank in a 69 nova? (1 replies)
  91. ls3 swap 65 Chevelle (5 replies)
  92. Break-in oil (9 replies)
  93. LS3 windage tray question (2 replies)
  94. value of LS7 with 5000 mikes. (9 replies)
  95. Recommendation on a LS1 stroker kit. (20 replies)
  96. LS known mounting/header/crossmember for Camaro (4 replies)
  97. New Engine Very low on power (29 replies)
  98. Anyone Running LS or OBD II MUST SEE THIS!!! (6 replies)
  99. Engine Management (0 replies)
  100. Questions for anyone running a 5th Gen fuel module. (0 replies)
  101. Budget LS3 'Connect & Cruise' mount advice (2 replies)
  102. 6.0 chevy van engine? (8 replies)
  103. LS1 fuel line to rail,firewall or frame to drivers side? (10 replies)
  104. quick question on 04 gto engine/trans (12 replies)
  105. 68 Camaro LS6 fit problems! (10 replies)
  106. Need the Advice from the Experts...LS1 Break in...Synthetic / Mineral Oil (5 replies)
  107. CORVETTE LS3 PAN in Camaro Nova Subframe (16 replies)
  108. Advice on cam choice (2 replies)
  109. Ls3 Engine builder? (2 replies)
  110. ID this throttle body for me? (2 replies)
  111. Please Help with Under Dash Mounting Ideas for ECM (12 replies)
  112. ats road race pan (1 replies)
  113. LS1 Accessory bracket bolt sizes (4 replies)
  114. ls4 (8 replies)
  115. LS1 carb cam - can I run this cam, should I run this cam (4 replies)
  116. Tell me what these spark plugs mean..... (39 replies)
  117. LS Dyno Tuning (Which oil) (5 replies)
  118. c6 corvette oil pan on 68 camaro (15 replies)
  119. LS build ideas need some help from those who've done it (4 replies)
  120. CTS V front acc drive (8 replies)
  121. Corvette Filter / regulator location suggestions 69 camaro (5 replies)
  122. Acc drive with LS7 and DSE sub?? (9 replies)
  123. Please read, need help, crappy running LQ4 in 03 Silverado. (30 replies)
  124. Feedback on Jegs Oil pan. (6 replies)
  125. Seems like a pretty goof deal on an LS3.. ready to go... (7 replies)
  126. LS ignition system - Is it inductive or CDI based (0 replies)
  127. Not Enough Clearance Between Champ Pans Oil Filter Adapter and Edelbrock Headers??? (2 replies)
  128. Am I better off ordering a crate based motor or having one custom built (2 replies)
  129. Pulley and bracket question with Daily dry sump system and remote water pump (0 replies)
  130. Speartech Harness in a 69 Camaro (18 replies)
  131. where to bolt chain hoist to LSA (8 replies)
  132. identify ls afr heads (10 replies)
  133. Ls2 swap? (5 replies)
  134. Ls7 questions.. too good to be true? (14 replies)
  135. ls1 carb intake (3 replies)
  136. Hiding coil packs, LS2 1981 Trans Am project X-Clean (1 replies)
  137. Front Accessory Drive ls3 69 camaro (8 replies)
  138. LS Camaro 1/4 mile times (16 replies)
  139. GMPP Controller kit (4 replies)
  140. More power from my LS1, how to? (13 replies)
  141. What parts did you use for your 1st gen f body ls swap? and would you use them again? (4 replies)
  142. Precision Race Components – SEE Why We Build Superior Cylinder Heads! (1 replies)
  143. Flex fuel (E85,93) high hp application? (15 replies)
  144. LS swap with a trans with no VSS, solutions? (15 replies)
  145. Question about running a supercharger and about 180* crossover exhaust (0 replies)
  146. Lsx 5.3 (13 replies)
  147. big block or small block heater core (5 replies)
  148. Lsx-454 (12 replies)
  149. Stuck! Custom Cooling Hose (11 replies)
  150. LS7 Intake Alignment Problem Need Help (0 replies)
  151. Whats the best and easyist way, swaping a c5 ls into a 69 camaro convertable cheaply? (5 replies)
  152. Holley Hi-Ram intake (2 replies)
  153. curious about real experiences with connect and cruise offerings. 376/525 (2 replies)
  154. ls Engine mounts (pics) not aligning (2 replies)
  155. Cut & weld LS Holley pan ? (12 replies)
  156. Low oil pressure "new" Mast Motorsports LS3 427 - what next? (26 replies)
  157. Custom LS2 Cold Air Intake (8 replies)
  158. Russel fuel filter adapter fittings? Good or not? (2 replies)
  159. Oil pan? (7 replies)
  160. LSX 454 PCV Catch can / Oil breather (21 replies)
  161. valvetrain question (1 replies)
  162. Engine Mngt Basics...HELP!! (10 replies)
  163. donor car? (4 replies)
  164. Hard Line for Sec Gen Camaro (Custom) (4 replies)
  165. I can't decide (20 replies)
  166. Possibly found a way to prime LSx engines! (7 replies)
  167. Ls1 engine swap ricks tank need venting? (5 replies)
  168. Good info source (2 replies)
  169. Anyone willing to rent a LSx valve spring compressor? (1 replies)
  170. H-beam vs. I-beam (5 replies)
  171. This is why GM is calling the all-new small-block an LT1 - ChevyHardcore.com (5 replies)
  172. Video Reveals New GM LT1 Engine Sporting Twin-Turbos? - ChevyHardcore.com (0 replies)
  173. VIDEO: GM Releases Gen V LT1 Videos, Showing Inner Details - ChevyHardcore.com (0 replies)
  174. Breaking News: Chevy Gen V Small-block Reveal! - ChevyHardcore.com (20 replies)
  175. Texas Speed & Performance Seeking Full-Time Salesperson (1 replies)
  176. LS3 DBW Throttle Body (5 replies)
  177. Holley HP EFI Help Needed (8 replies)
  178. Seized Pilot Bearing? (5 replies)
  179. LS3 525hp tune with LS1 pcm? (0 replies)
  180. LS1 and an accumulator? (0 replies)
  181. L92 "821" head on LQ4. (12 replies)
  182. Should I Pull The Trigger?? (29 replies)
  183. Lost oil pressure at RTTC with Mast pan (10 replies)
  184. How To Fuel Tank Setup For LSx (16 replies)
  185. Modifying lq-9 with stock 317 heads (8 replies)
  186. Alternator output voltage is low (11 replies)
  187. Two diff heads on the same motor?? (2 replies)
  188. ls swap fuel lines (16 replies)
  189. Carbed lsx cutting out (1 replies)
  190. LS2 AC/ALT Bracket help (0 replies)
  191. 2nd Gen Camaro LS Throttle cable....did you guys use some thing OTHER than lokar?? (6 replies)
  192. Need advice. Ls2 t56. What best bargain (8 replies)
  193. LS7 Valve Train Questions/Concerns (16 replies)
  194. LSX376 Valve Covers (8 replies)
  195. Front Acc Drives (2 replies)
  196. Heater Core for LS application (3 replies)
  197. Holley LS accessory brackets. (24 replies)
  198. LQ4 in my truck is missing bad only when cold, what should I check? (11 replies)
  199. LS3 Power steering pump coming apart? (3 replies)
  200. Need Spark Plug Wires for 69 Camaro w/ LS2 & Stainless Works Headers (3 replies)
  201. LSA Short/long block? (4 replies)
  202. Edelbrock E Force Supercharger and AC compressor (0 replies)
  203. gauges with LS (2 replies)
  204. LS Champ Pan/GM A Body (2 replies)
  205. Eye Candy: Texas Speed's '55 Nomad with a Supercharged LS6! (2 replies)
  206. How much pressure on C5 regulator return line? (4 replies)
  207. ls3 engine harness (12 replies)
  208. Muncie will it work? (9 replies)
  209. 6.0 Iron cylinder heads (12 replies)
  210. Oil pan clearance (2 replies)
  211. LS3 Install in 69 camaro (5 replies)
  212. LS3 Install in 69 camaro (0 replies)
  213. Couple of "finishing" up questions. (12 replies)
  214. Wiring my engine, Knock sensor?? (7 replies)
  215. 1st Gen Camaro ISsue (3 replies)
  216. Ls front assessories not in line? (2 replies)
  217. ATS Clutch bracket question (1 replies)
  218. 67 camaro ls1 question (5 replies)
  219. 99 Caprice as a LS1 donor??? (5 replies)
  220. new holley swap parts (4 replies)
  221. Researching options for engine rebuild in my 03 2500HD (10 replies)
  222. Motor mount troubles (2 replies)
  223. 1998 L29 Vortec 454 potential? (5 replies)
  224. What is the deal with the fuel clamp like thing on LSX engines? (15 replies)
  225. LS1ick68: My Ls1 swapped 68 c10 (7 replies)
  226. MAF sensor question (3 replies)
  227. LS1 pricing (8 replies)
  228. GM's new Gen V LSX engine. (14 replies)
  229. i need suggestions about notching front subframe to fit oil pan; a-body with lsx (10 replies)
  230. need intake info (2 replies)
  231. Need a Road Race LSX Oil Pan Chevelle A-body (11 replies)
  232. GM LS3 crate motor connect +cruise - opinions? (1 replies)
  233. 67 camaro ls9 (2 replies)
  234. Ls1 with low miles (17 replies)
  235. LS1 Swap 68 Camaro questions (23 replies)
  236. L99 good choice for swap? (16 replies)
  237. Clutch grabbing at the top (4 replies)
  238. New to forum. 67 chevelle lm7/t56 going in (2 replies)
  239. Advice Needed On Bearing Clearances (4 replies)
  240. OEM style nylon style fuel lines? (4 replies)
  241. P/S Pump bleeding (4 replies)
  242. 2nd P/S pump making noise??? (6 replies)
  243. Mike Norris Motorsports Tuning in Socal Around The First Week of October, 2012 (4 replies)
  244. Oil / Water gauge sender Adapters (1 replies)
  245. LQ9 Pulsed Cooling Fan output? (3 replies)
  246. LS1 and SBC Mcleod Bell? (6 replies)
  247. Twin turbos for a LS2 69 Firebird (4 replies)
  248. Lsx wt vs sbc weight (7 replies)
  249. 69 camaro ls3 w/magnusun blower front drive system? (4 replies)
  250. Head/cam swap done, Who can run in SoCal? (0 replies)
