View Full Version : few questions ls1 into an 88 monte carlo ss
creamgorilla
06-19-2013, 10:25 PM
I found an ls1 I'm wondering what the swap will actually cost me. Stock 305 and transmission coming out. New ls1 with transmission going in. Ls1 comes with ecu. What parts will I need to buy to make this thing work?
Looking for cost as in which parts I need not Labor cost etc
howehot
06-21-2013, 05:16 AM
Engine plates, motor mounts, exhaust, new radiator and hoses, EFI fuel tank, pump, sending unit, Corvette filter. If you are keeping AC you will need an Olds condenser, new hoses. Probably a new driveshaft.
The cost add up but you will be very pleased with the results.
The tank, pump and sending unit I got from rockauto. Look up the parts for a V6 1988 Monte or Grand National. The corvette filter Has a built in regulator and return port. Also got the AC condenser through them.
RND fabrication is coming out with a line of dropin radiators for a G-body. They are doing the first LS unit for me now. It will have both hoses on the right side, a steam port, and trans cooler. For a top hose I trimmed the factory Monte unit. I don't have the number for the lower I found that worked but can provided it if needed. Info is in the shop.
There are several companies offering conversion kits. Stick with one company for headers, motor mounts and trans cross member. They are designed to work with each other with the given engine placement. BRP hotrods has some nice stuff and will provide info.
There wil be other pieces that will popup but these should be the bulk of large parts
creamgorilla
06-22-2013, 11:16 AM
Thanks that helps a lot. Really appreciate it
SparkyRnD
06-28-2013, 07:45 PM
Dan is correct, and the radiators are now available for purchase. Takes us about 2-3 weeks in most cases as each one is hand made here in the USA, and Tig-Welded one by one. You can get them here:
http://www.rndfabrication.com/Gbody.html
(make sure to ask for your Pro-Touring.com member discount when ordering)
https://static1.pt-content.com/images/pt/2013/06/Gbody1-1.jpg
