View Full Version : Muncie will it work?
philman
08-12-2012, 08:47 PM
Hello everyone .. a couple of questions first a little backround 69 firebird with 400/4sp muncie converting to a ls3. I have a line on a 22thousand mile ls3 running in a 08 vette. He wants 5k does this sound fair? also I would like to use my rebuilt muncie four speed and drive shaft to cut down on cost is this possible? thanks in advance Phil
08-12-2012, 10:02 PM
5K is a great price for a running LS3.
You could use the Munc with the right bellhousing, clutch and release bearing. You can use a z bar but that will depend on the headers that you will use.
We ran a Quick time Bellhousing pn RM-6036, Mc Leod 1308 hydraulic release bearing, 2001 Camaro T56 pilot bearing (small) and GM LS3 Clutch. You will need a 10 spline clutch disc.
garys 68
08-13-2012, 12:34 AM
Motor sounds reasonable if you get accessories, harness, ecu, pedal, etc.
As for the Muncie
http://ls1tech.com/forums/conversions-hybrids/1472584-mating-sbc-bbc-trans-t10-muncie-richmond-tko-ls-motor.html
Oakesters
02-24-2013, 09:21 PM
How many people run muncies with ls1s?
Flash68
02-24-2013, 09:58 PM
maybe 1 in 500?
garys 68
02-25-2013, 04:52 AM
Um yeah, that would be me. But mine was a cost factor and worked well with my combo.
Heavy 72 Olds, 2.73 rear, relatively small 5.3, so a T10 4 speed with 3.42 1st works out pretty well as a daily driver.
There are a few weight concious swaps using them too.
maybe 1 in 500?
badazz81z28
02-25-2013, 06:37 PM
I know easier said than done...but I would sell that 4 speed and pick up a Magnum or a TKO. The modern engine is just that much more better with an OD trans. Which muncie is it? May have good re-sell value.
Oakesters
03-03-2013, 03:47 PM
Just thinking of a cheaper way to get a ls swap done , didnt the 48 hour camaro has a muncie?
BuzzKillian
03-03-2013, 06:43 PM
Just thinking of a cheaper way to get a ls sway done , didnt the 48 hour camaro has a muncie?
That's what it started out with + a Gear vendors OD. It has T56 Magnum in it now. (unless they changed it again, since last time I talked to Bret)
garys 68
03-04-2013, 05:22 AM
Another advantage in the 68-72 A bodies, no cutting the tunnel. T56s are too big.
