View Full Version : 2005 Silverado donor truck for my 68 camaro questions?
astross89
05-29-2013, 04:28 PM
Just bought a 2005 Silverado truck for the motor, transmission, and harness. I have a couple questions. What all can I use. I know I can use the motor, tranny, harness, and ecm. I have a Ls1 intake for it already. But can I use the front runner set up? radiator? Any other parts I can use? Also I heard problems use the wrong drive by wire pedal with the wrong computer not reading. But sense the computer and pedal come from the same car, I should be good to go? and if I use the pedal and computer from the truck, Can I use the drive by wire corvette tb?
https://static1.pt-content.com/images/pt/2013/05/608-1.jpg (http://s4.photobucket.com/user/astross89/media/608.jpg.html)
astross89
05-30-2013, 10:42 AM
anyone?
Z06vet
05-30-2013, 03:39 PM
OK I havent done this exact swap, but I can help a little. The rad is likely out, as its probably too wide. The 98-02 Fbody works well though. I think you'll be ok with the vette TB, but have not done a DBW swap yet. Have you checked to see if the plugs on the vette TB are same as truck TB? I also think you can use the truck acc. by using a bracket made by qwik (i think holley may have one now too) to relocate one of the idler pulleys so the car intake/TB will clear it. May be close on hood clearance with truck alt but it will depend on which mounts/stands are used (how high they mount the motor, as well as fore/aft location. Give it some time & one of the guys on here with first hand experience will give you a def on your questions. Truck motor into 1st gen is as common as it gets. Scott
armourmark
06-01-2013, 05:18 PM
You can use the truck accessories with the kwik brackets. Truck manifold will not clear the hood, even if it's a cowl induction hood. Not sure about the DBW, I swapped my truck manifold for a LS6 and went to DBC for simplicity. BTW, I have a LQ4 out of a 2007 in a 67 camaro with CarShop setback plates.
