View Full Version : 6.0 Iron cylinder heads
65MALI
08-11-2012, 11:24 AM
Are there any good use for stock iron 6.0 cylinder heads or are these just worthless boat anchors? I have a set I was looking to mate with an Ls1, but was wondering if the it was worth the effort. Yes I did do a search, couldnt really find any info.
SLO_Z28
08-11-2012, 11:48 AM
The iron block LS engines all had Aluminum heads.
daytonayellaz
08-11-2012, 12:17 PM
I do beleive there were some early LS based motors that had some iron heads on them... Trucks/vans. But honestly... I would buy a set of aluminum heads and not use the iron ones. I have a set of aluminum LS1 heads if needed.
srh3trinity
08-11-2012, 12:22 PM
You can find aluminum ls all day long for cheap. They would be worth it for weight savings alone.
cmac06
08-11-2012, 02:04 PM
The 317 heads flow pretty good, and are dirt cheap. I am using a set for a FI motor to lower the compression. With a little port work, the flow becomes really respectable for the amount of money put into them.
65MALI
08-11-2012, 05:41 PM
Thanks for all the replies, Im sure aluminum is the way to go, but heck, I already have the iron 317 heads, might as well put it to use. I just wasnt sure if i would lose horse power or gain horsepower.
tflyboy77
08-11-2012, 06:30 PM
You will loose hp because I believe the 6.0 has lower compression heads than the smaller LS motors.
65MALI
08-11-2012, 07:21 PM
Ahh, Got it.
Chevelle598bb
08-11-2012, 09:16 PM
Between the iron and aluminum 317 head you would see the same compression ratio. The only factory head that is better than the 317 is a 243/799. The 317 and 243 have the same ports but a larger chamber. If you put a 853 or 241 you will gain a little compression but loose flow which in turn loose power.
65MALI
08-11-2012, 09:51 PM
Never ending info on this site.(Need to post more) I think ill slap on the 317 heads, better springs,and a descent cam and be done with it.
garys 68
08-12-2012, 04:32 AM
Just an FYI, if you have a 99-00 iron truck block with iron heads, it has a longer crank that can only be used with auto trans. And I'm not sure if it will mate up with both a 4L60 and/or 4L80.
Chevelle598bb
08-12-2012, 04:42 AM
It will mate up to both the 4l80 and 4l60. You just have to make sure you get a converter for a 99-2000 truck which has a shorter pilot.
08-12-2012, 10:06 PM
What if he wants to run a th400?
