View Full Version : LS1 pricing
josh96z28
07-18-2012, 09:37 AM
How much would it be to put a ls motor in my 96 z28 ? Please and thank you
MuscleRodz
07-18-2012, 09:54 AM
ls1tech.com would be a better place to get your answer than here.
Rod
07-18-2012, 10:01 AM
welcome to the forum
thats like asking how long is a piece of string?
Vicinity
07-18-2012, 10:45 AM
What kind of LS motor?
What kind of transmission?
Stock reworked harness or new harness?
Answer these questions and each goes into 2 more questions. etc.
Best bet is to do a ton of research, then spend a few more hours researching. As said above, start reading over at LS1Tech.
rockytopper
07-18-2012, 11:09 AM
It would be cheaper to sale the 96 and buy a 98 & up with ls1 already. They are a dime a dozen these days.
Project92rs
07-18-2012, 02:53 PM
Agreed. You can find 98 up LS1 cars for under $5k periodically which would be cheaper than the swap
LS1-IROC
07-19-2012, 02:50 AM
I spent $10K to put a brand new crate LS1 and T56 into my 3rd gen. But that was 7 years ago..if you bought all used stuff you could do it for alot less..probably in the range of 4-5K. I'd just buy a 98-up now because they are CHEAP!
07-19-2012, 09:51 PM
https://static1.pt-content.com/images/pt/2012/07/drevil-1.jpg
I bet he knows how much...
Chevelle598bb
07-19-2012, 10:56 PM
I had about 5 grand in my swap which included a built ls1 a customer did not pick up. My camaro was a 94 and originally a v6. If you are attached to the car then it can be done but will cost some cash. Here is a parts list.
Engine
Trans
Engine harness
Front k member
Rack
Steering shaft
Exhaust
Headers
Ac lines - 96 v6 work great for ls swaps
Air intake set up
Fuel pump
Regulator/filter
Computer
Tuning of computer
Nickle and dime stuff
I swapped mine since I had most of the parts and the camaro was super clean and had been in my family since new. Most economical would be to sell yours and buy an ls car. You would probably only be out 1000-2000 instead of 5000-10000k.
If you must do the swap then the engine harness is very easy to configure to the 96 lt harnesses. You can use the stock lines and the corvette filter regulator in the stock location, 96 v6 camaro ac lines for the ls1 ac compressor, computer bolts in stock place, get matching y pipe to whatever headers or manifolds you are using and you will have to fab an air intake.
