View Full Version : 6.0 chevy van engine?
twisted biscayne 60
02-28-2013, 04:22 PM
does anyone know if a 6.0 chevy van 2004 is a good engine to use in a swap? do people use these to get good power out of as a start?
hifi875
02-28-2013, 04:58 PM
Yes any ls engine is a good candidate. Cam it at a minimum. Great motor
Rhino
02-28-2013, 05:06 PM
While not in a car, I did swap one into my Avalanche. I'd agree it's a good motor, however you'll likely want to swap heads as well. They flow erl for stock, however the LQ4's dished pistons and big combustion chamber yields a pretty low compression ratio.
garys 68
03-01-2013, 05:14 AM
The vans are known for having oddball TACs and pedals. Be sure to get those with the motor. Great motor though.
2yellow69
03-01-2013, 03:43 PM
Got my 6.0 out of a 2004 van. It had been t-boned with about 130,000 miles. Was a little leery about it's maintenance because it was a delivery vehicle. Upon disassembly it was very clean inside. It must have idled a lot. The cylinders were glazed but still in spec. I just ran a hone through it. By the way, mine had the dished LQ4 pistons but it also has coated skirts and floating pins on them!!
twisted biscayne 60
03-03-2013, 02:00 PM
thanks for the help
T.K.
03-04-2013, 07:53 PM
dont know if it matters to you but that is an iron block not al
SparkyRnD
03-13-2013, 06:46 PM
that's what we're using in Project Sabre, from a 2003 express van
cmraman
03-13-2013, 07:55 PM
Ask Randy Johnson from D&Z Customs.
