View Full Version : AC Compresser notch panel
hotrodneb
06-02-2013, 10:05 AM
Sometime during all my internet reading I came across someone who made a pre-formed piece that was made for notching the subframe for a passenger side low mount AC compressor. It my memory thought it was DSE, but couldnt find it on their site.
Any help here for an old guy with a bad memory???
hifi875
06-02-2013, 04:49 PM
Brp hot rods. I have one in my 69
hotrodneb
06-03-2013, 01:41 AM
That is IT...Thank you.....you may now carry the title genius for the day
and ony $25 too
Boostable
06-06-2013, 02:53 PM
hifi,
Any details on your setup? I have a notched frame as well, but have not got the power plant in it yet. What compressor you running? Drive setup?
hotrodneb
06-07-2013, 02:32 AM
'68 firebird with LS1/4L60E conversion in progress donor was a '98 Firebird
Bowler trans crossmember from member here
eGay cheap adapter plates
Replaced pontiac engine stands for small block stands and mounts in "stock position
Stock F-body engine accessories
Dumped stock AC compressor (variable output) for TRSA12B (Trailblazer SS-fixed)
GM part # 12593247 bracket and Dorman #419-109 tensioner
The bracket required EXTENSIVE modification that could NOT be done by most. I had to modify and move the entire bracket rearward 0.400" but was able to finally get it to run in the original position and off the 4-rib belt. I have JUST enough clearance between the compressor and engine mount for the head of the through bolt, and will have to modify one leg of the stand when doing the frame notch.
hifi875
06-07-2013, 05:52 PM
hifi,
I am running corvette c5 accy with a sanden compressor with the vintage air adaptor plate. Works perfect. Been on car for 5yrs
