View Full Version : spal fan sensor
mattdirocz
04-25-2013, 08:10 PM
I am getting everything ready to put my carbed 5.3 in my camaro and can not figure out how I am going to use my fan. I have a spal fan and relay kit. The fan sensor is 3/8 and I can not seem to find an adapter to put it in the head. Is there a way to get a different sensor that is metric I can install. I believe it is a 12mm, I am stuck and have searched LS1tech and here looking, Thanks for any help
Evldoer
04-29-2013, 12:43 AM
I dont think you will find an adapter to fit a 3/8 pipe to the head, you would have to use multiple pipe adapters to get it to fit, and that is really going to look like hell. I would consider drilling out the hole with a 9/16 drill and use a pipe tap to thread the hole so you can install that sending unit properly.
Rhino
04-29-2013, 12:40 PM
They come in many autometer kits, I'd feel pretty confident saying that they could likely be purchased separately.
I do know that at one point in time S&P sold one pretty cheap. It's been a few years so I'm not sure if it's still available.
Reactor
04-29-2013, 03:36 PM
I had the same issue and drilled and tapped the pass head for the 3/8" sensor. I could not find a 160 degree switch anywhere that was metric. Just drill it and you will be good to go.
mattdirocz
04-30-2013, 06:50 AM
Thanks for the help guys. I guess I better break out the drill. I look at s&p and it looks like that adapter was 14.99. I will just drill it out and tap thanks for the help
