View Full Version : Recommendation on a LS1 stroker kit.
howehot
03-08-2013, 08:34 PM
After spinning a rod bearing, well several the way it sounds, the LS1 is in need a a new crank and some rods. Just a well add some stroke to it.
Looking for recommendation for a strokes kit.
howehot
03-21-2013, 10:39 AM
Here is what the builder and I have settled on, a Callies Compstar stroker kit. 4.00" stroke forged crank, 6.125" forged rods. 3.903 forged pistons. It will now displace 383ci or 6.3L. Pump gas friendly with 10.6:1 compression and should be really close to 600 horse according to his computer dyno.
Slick68
03-23-2013, 07:45 AM
That's probably the direction I plan to go with mine if it ever goes. That may not be much longer the way I drive it now. lol
BTW, love the way you built your car. I wish I could something similar with my dad's MCSS.
srh3trinity
03-23-2013, 01:19 PM
The Callies stuff seems to be the way to go in the LS world. That is what I am using with Mahle pistons for my ls3
howehot
03-23-2013, 07:10 PM
I had Mahle pistons prior to the stroker kit. I believe the Callies kit comes with wiesco pistons.
howehot
03-23-2013, 07:13 PM
Thanks. Hold on to your dreams and you never know how they may workout.
Slick68
03-24-2013, 06:35 AM
Thanks, man! Right now my dreams are being put into my 68 C10. I'm planning on building a new chassis for it and "build" the LS1 in a couple more years. My dad has an 87 MCSS he built back in 04. He is currently thinking of selling it. If I didn't already have the truck, I would buy it and upgrade the suspension first, then maybe look into a whole new chassis later with an LSx/6 speed combo. My first car was an 83 ElCamino SS, so I certainly have a desire for another G-body car sometime.
srh3trinity
03-25-2013, 06:41 PM
I ordered my Callies crank and rods today. I think there is about a 10-14 day lead time. I can let you know how the look when they come in. Supposed to come with a rough balance, but I am supplying my own pistons, so my machinist will have to finish the job.
howehot
03-26-2013, 06:55 PM
My builder made it sound like he would have it midweek after ordering it last Thursday. He said he should be completed with the build in a couple weeks but I thought it would be completed by now. I also believe it comes fully balanced with the provided pistons which I think are Wiseco.
One thing about it. Warmer weather is in the forecast and I can wait for the next outing with my Monte Carlo!
CarlC
03-27-2013, 10:12 PM
What cylinder heads are you going to use?
howehot
03-29-2013, 05:08 PM
Using the factory 243 castings that had some port work done. I also use a LS6 intake.
srh3trinity
03-29-2013, 06:01 PM
Mine is going to have stock LS3 heads and intake. I may port down the road.
howehot
04-04-2013, 05:53 PM
Parts were received last week. They should have it back together first of the week, at least that what they told me today. I would think that 6 weeks should be plenty of time to get an engine rebuilt.
howehot
04-13-2013, 05:27 PM
Lastest update is the the clearancing of the block is done and the short block is ready for final assembly. Told me they guaranteed it would be done Friday the 19th. I will not hold my breathe. That will make it over 8 weeks to get this out of the shop. Pretty sure I will find another builder for the next one.
Rybar
04-17-2013, 03:23 PM
I just swapped to a forged 383 LS1 bottom end bought from LS1tech classifieds. These are the parts it came with.
LS6 383 Callies C-Series LS1 4.000 Crankshaft 24 tooth
Scat 4340 LS1 I-Beam 6.125 (.015 offset) Part # 2-ICR6125-7/16
Wiseco K464F3903 LS1 3cc Pistons 3.905 Bore 391g each
The car just made 496 rwhp 469 rwtq on a Mustang MD-1100 chassis dyno so your builders estimate is not far off.
I'm running ET Performance 215cc heads, ported Fast 90/90 and a custom 235/242 cam from Engine Power Systems.
howehot
04-18-2013, 07:02 PM
Engine is back in the Monte, not running yet but in.. Snow tonight and rain forecasted for the next 7 days.
kainedogg
04-18-2013, 11:21 PM
I just swapped to a forged 383 LS1 bottom end bought from this site classifieds. These are the parts it came with.
how much was the short block?
howehot
04-19-2013, 05:49 AM
To rebuild my short block with honing and clearancing, , clean and reassemble the heads, and new head gaskets, out he door was $4166. I thought this was a pretty good deal except for the 8 week turn around time. He used the Callie's speed pack with JE pistons.
howehot
04-30-2013, 07:04 PM
Finally got it running this evening. Started right off and sound great. Now to let the FAST EFI do some relearning and some break in miles. Heidts event is next weekend.
LSXperformance
04-30-2013, 08:14 PM
sweet!
howehot
05-07-2013, 07:39 PM
The performance increase of the LS383 is incredible. The top end never changed except for the head gasket thickness which increase compression to 11:1 vs 10.5:1 in the LS1. The torque increase can really be felt. The power is seamless, the 335/30/18 KDWs are look for bite as this engine will burn em up.
