View Full Version : Fuel Injection
Pages : 1 2 [3] 4 5 6 7
  1. Holley efi questions (0 replies)
  2. Pontiac 400/455 Fuel Injection??? (12 replies)
  3. Throttle by wire TB needed for Holley Stealth Ram intake (3 replies)
  4. Air Cleaner with FAST EZ-EFI, Speed by Spectre (3 replies)
  5. MSD Atomic FI (18 replies)
  6. help me... I dont know whats right on FPR (9 replies)
  7. How to help prevent your car from burning to the ground - A real life example. (22 replies)
  8. Need to get educated on Holley HP EFI (19 replies)
  9. Resealing a galvanized tank after modification? (1 replies)
  10. Holley Performance Products Terminator EFI (64 replies)
  11. Post your fuel line coolers (5 replies)
  12. Fuel Tank (8 replies)
  13. I'm in the market for self-learning EFI kit, 3 options. (14 replies)
  14. Losing fuel pressure during hard acceleration?? (4 replies)
  15. Anyone has the new Aeromotive F-body Stealth fuel tank ? (3 replies)
  16. FAST Vendors? (1 replies)
  17. MSD Atomic EFI LS use with supercharger (2 replies)
  18. Fuel line routing 69 camaro art morrison chassis (2 replies)
  19. Pro-Flo In A 69 Camaro (0 replies)
  20. Accel DFI tuning help - won't idle (6 replies)
  21. New dse fuel tanks (8 replies)
  22. EFI fuel rail plumbing (3 replies)
  23. Who uses foam in a fuel cell (3 replies)
  24. Efi throttle cable bracket (0 replies)
  25. Long range fuel tanks (4 replies)
  26. Rick's tank with Vaporworx (8 replies)
  27. Anyone Used This EFI Tank????? (7 replies)
  28. tanksinc / aeromotive stealth tanks? (2 replies)
  29. Fuel pump controller to solve overheating fuel issue? (0 replies)
  30. Best ECU to use? (3 replies)
  31. FAST duelsync distributor for Mopar 440 (0 replies)
  32. Fast efi 2.0 (106 replies)
  33. Aeromotive Pump fell apart; help needed.... (0 replies)
  34. EFI Tuning Question (Big Blocks, Blowers, Flat Spots at ~3K RPM) (6 replies)
  35. Best Fuel Resistant Silicone Sealer?? (7 replies)
  36. fuel pressure gauge on fuel rail flutters (9 replies)
  37. Please help me identify these fuel injector plugs and the injectors? (5 replies)
  38. Powerjection 3 forum (1 replies)
  39. BBC EFI Intake Question (3 replies)
  40. Rick's/Vaporworx Stainless Tank Install Questions, 67 Camaro (3 replies)
  41. Fuel line routing tank to frame 67 Camaro ls1 (0 replies)
  42. II Much Vent in a Sec Gen Camaro? (25 replies)
  43. installed the MASS-FLOW fuel injection crappy miliage.... (12 replies)
  44. Any reason why not to mount regulator close to tank? (0 replies)
  45. Yet..ANOTHER issue with Rick's Tanks (21 replies)
  46. Extra Fuel Filter (0 replies)
  47. MASS-Flo Installed realy liking it... (2 replies)
  48. fuel tank breaths when I remove gas cap (7 replies)
  49. '68 Lemans gas tank with ls swap (0 replies)
  50. Needing help with electmotive fi (2 replies)
  51. Holley EFI Users, Step Inside Please (224 replies)
  52. tunnel ram with dual tp doable???i (8 replies)
  53. Pre-Crimped Fuel Hose? (3 replies)
  54. Terminal Crimpers for e38 terminal (12 replies)
  55. Venting Rick's Tank (11 replies)
  56. Trial start up with Stealth Ram (4 replies)
  57. Rick's Tank sending unit bolt size? (4 replies)
  58. Plumbing SBC EFI fuel rails (4 replies)
  59. Fuel cell ? (4 replies)
  60. computer location for a 1st gen camaro (2 replies)
  61. building an EFI system with LS electronics ? (5 replies)
  62. Air Temp/Coolant Temp Sensor (3 replies)
  63. Injectors not firing... (5 replies)
  64. Another overheating fuel question (9 replies)
  65. need help with EFI decision (6 replies)
  66. tank material ? (10 replies)
  67. Need Input: 340LPH In Tank Fuel Pump (0 replies)
  68. Second Gen fuel tank mounting locations (8 replies)
  69. Need ideas for fuel system for hilborn efi injected sbc in a wagon (4 replies)
  70. series dual fuel presure regulators (0 replies)
  71. LS7 Intake--Foam Pads (7 replies)
  72. EFI Live Training Classes (1 replies)
  73. I have fuel psi issues (3 replies)
  74. EFI vs LS (1 replies)
  75. Summit Teflon -6 AN hose for fuel (2 replies)
  76. More Holley Dominator problems (7 replies)
  77. Help with Aeroquip fittings. (3 replies)
  78. Fast ez efi (10 replies)
  79. How Does PWM actually control the fuel pump motor? (2 replies)
  80. First gen camaro fuel system options to support 800whp on e85 (8 replies)
  81. FAST XFI fuel injectors (9 replies)
  82. Mike Norris Motorsports EFI Tuning in Socal Around The First Week of October, 2012 (1 replies)
  83. Bought a Rick's Tank!! 1978 Camaro (9 replies)
  84. vapor lock issues with efi system (6 replies)
  85. Projection 4i Help needed (3 replies)
  86. Fuel Pump Speed Management (0 replies)
  87. Wiring Holley HP to MSD (0 replies)
  88. Best Returnless fuel EFI recommendations (3 replies)
  89. Holley hp efi sensors (15 replies)
  90. Need advice on bending 1/2" .035 wall stainless tubing (4 replies)
  91. Commander 950 TBI to HP TBI Computer! (6 replies)
  92. MSD latest EFI unit (0 replies)
  93. Summit bulk fuel line ok for LT1 swap? (5 replies)
  94. Holley dominator EFI issues (24 replies)
  95. Anyone use PTFE fuel lines from Frozenboost? (18 replies)
  96. EFI reg. mounting. (1 replies)
  97. Dse narrowed gas tank ?????????????? (1 replies)
  98. Knock sensors - Does anyone use them? (5 replies)
  99. Russell Quick connect fittings-New version (3 replies)
  100. Holley hp power source (3 replies)
  101. fuel pressure regulator location (4 replies)
  102. propane injection (20 replies)
  103. Ricks tank with Vapor Works finally made it to my house. (12 replies)
  104. Excessive Cranking to start...Fuel system??? (6 replies)
  105. Anyone know a good Fast XFI tuner in MD? (2 replies)
  106. gas pedal conversion (4 replies)
  107. How I justified switching to EFI. Agree or disagree? (18 replies)
  108. which pump for grand national fuel tank (0 replies)
  109. Powerjection III EFI unit - 1st start won't run (8 replies)
  110. Reversed Fuel Sump (1 replies)
  111. Victor E intake help (4 replies)
  112. Powerjection iii vs avenger efi? (0 replies)
  113. Injectors for Holley HP efi (7 replies)
  114. fuel pressure loss (6 replies)
  115. Edelbrock Fuel Injection Manifold for Mustang 5.0 - Question (3 replies)
  116. FAST XFI 2.0 Tuning (2 replies)
  117. Nes FAST EZ EFI Multiport systems for 1000 HP - any expereince? (3 replies)
  118. Efi (13 replies)
  119. Rick's Tanks Question (2 replies)
  120. fast ez-efi on 302 sensor locator problems (3 replies)
  121. Need a dyno shop in the san jose, ca area (1 replies)
  122. Fuel lines, system plans.... (12 replies)
  123. fuel injection for 455 oldsmobile (2 replies)
  124. Stainless steel OEM style stamped tank (7 replies)
  125. need advvice on fuel system design and execution for EFI conversion (8 replies)
  126. MSD Atomic EFI (12 replies)
  127. Need ideas on hoe to mount fuel line to fire wall? (0 replies)
  128. MPFI Fuel Rails (0 replies)
  129. A low cost EFI tank option. Retrofuel? (11 replies)
  130. Turbo stroker or not (16 replies)
  131. Carb to EFI experts please chime in. (25 replies)
  132. Mechanical Fuel Pump (2 replies)
  133. Aeromotive Fuel Tank for 1st Gen? (44 replies)
  134. Mike Norris Motorsports EFI Tuning In SoCal - RTTC 2012 March 8-11 (1 replies)
  135. Best EFI for supercharged TPI (10 replies)
  136. lokar throttle cable 69 camaro (4 replies)
  137. Rick's / VaporWorks Electrical connectors -- source? (7 replies)
  138. New Camaro Zl1 fuel module (17 replies)
  139. need fast ex efi help! new install (4 replies)
  140. Coil on plug wire harness (6 replies)
  141. NEED HELP! Hilborn fuel injection (3 replies)
  142. Fuel injector size help!!! (16 replies)
  143. Holley HP EFI in a miata (7 replies)
  144. For the guys who have yet to checl out Megasquirt, here is DIYAutotunes display, COOL (2 replies)
  145. Inline check valve (0 replies)
  146. Fuel filter mounting issue (3 replies)
  147. First Gen Aeromotive Fuel tanks (3 replies)
  148. fuel line leak testing (1 replies)
  149. Is there an FI tank for 78-81 Camaro? (3 replies)
  150. EFI ECM: which would you use, and why? (3 replies)
  151. Pictures of Fast Fuel Injection system (9 replies)
  152. Vaporworx? Turbo LS tank solution? (5 replies)
  153. What intake to use (32 replies)
  154. Ricks Tanks, what is this? (2 replies)
  155. stainless to aluminum? (2 replies)
  156. EFI gas tank...with or without Evaporation Emission Control (1 replies)
  157. fuel line fittings with c5 filter/regulator (9 replies)
  158. Replacement pump for Spectra GM32BFI in my 69 Camaro with LS1 motor (3 replies)
  159. Mike Norris Motorsports EFI Tuning In SoCal After SEMA - Nov 7-9 (1 replies)
  160. TPS Values - not what I expected (6 replies)
  161. Throttle Body or multi port? (2 replies)
  162. Fast ez-efi ? (8 replies)
  163. Blower EFI input (4 replies)
  164. Local tuner (6 replies)
  165. Gas tank question/ Holley avenger EFI (3 replies)
  166. fuel pressure regulator? (17 replies)
  167. Tubetech nylon fuel line??? (3 replies)
  168. Cost of a basic LS swap (1 replies)
  169. Trying to decide on efi setup and throttle body questions (3 replies)
  170. Help with Late Model GM Fuel Sender Assembly Retrofit (10 replies)
  171. adding a baffle to fuel tank? (9 replies)
  172. Holley Dominator on a Ford Mod Motor (7 replies)
  173. my olds 455 efi conversion (23 replies)
  174. External Surge Tank and Cheap EFI Tank? (25 replies)
  175. Tuned port injection a good bet? (22 replies)
  176. converting a Chrysler 383 to LS fuel injection (4 replies)
  177. Life with a fuel cell?? (6 replies)
  178. Stainless tubing questsion (23 replies)
  179. fuel injection system for 650+hp (0 replies)
  180. Fuel or igniton problem with Accel Gen 7 (6 replies)
  181. Fuel injection with a Twin turbo? (10 replies)
  182. Anti-Seize on O2 Sensor threads? (4 replies)
  183. Holley EFI is the best (9 replies)
  184. FAST XFI Tuning in Houston (0 replies)
  185. Wiring up tach signal (0 replies)
  186. Light Throttle Miss - EZ EFI Multiport (0 replies)
  187. how mutch HP can these parts diliver (8 replies)
  188. hardline to flex line fittings (17 replies)
  189. EZ Idle Issues (5 replies)
  190. Best Fuel Management for Twin Turbo First Gen (13 replies)
  191. 2nd gen tank suggestions (24 replies)
  192. Fuel Line Plumbing? (19 replies)
  193. who can convert a carb intake to efi? (11 replies)
  194. Help identify fuel-cell thread. (6 replies)
  195. ez efi and fuel pressure regulator (0 replies)
  196. EZ Issues (3 replies)
  197. touring 70 monte, convert to FI (4 replies)
  198. Ez efi (1 replies)
  199. EZ EFI Problems: someone has to be able to help..... (14 replies)
  200. vapor lock heat problems (24 replies)
  201. injector size (3 replies)
  202. Russel Fuel rail adapters for LT1 to AN-6? (21 replies)
  203. Need some help figuring out where to start troubleshooting the wife's 01 Tahoe (5 replies)
  204. Fast EFI question (21 replies)
  205. Carb to EFI - Need help.. (7 replies)
  206. 2010 camaro pump and Ricks Tanks (4 replies)
  207. 70 Chevelle LS6 - Should I put an EFI? (4 replies)
  208. Help me find fuel lines (4 replies)
  209. Throttle body size advice (6 replies)
  210. redline weber efi (0 replies)
  211. homemade fuel injection system what will I need? (10 replies)
  212. 95 LT1 running rich (1 replies)
  213. Help me make a shopping list!! (injectors, pump) (8 replies)
  214. Spectre tank pump rating (0 replies)
  215. Help me verify FAST Fuel Rail pt# (0 replies)
  216. Fuel Pumps and pluming help needed. (0 replies)
  217. Kicked out of the Garage!! EZ EFI fuel line odors. (35 replies)
  218. Any sponsers a dealer for Nick Williams? (2 replies)
  219. EZ EFI fuel system plumbing (mopar content, but any help is appreciated) (2 replies)
  220. Help! Which EFI system is best for an 8-71 Blown SBC 406 CI? (2 replies)
  221. Ez-efi or xfi ???? (2 replies)
  222. 68 camaro LT1 to Rick's tank fuel line length??? (5 replies)
  223. Fuel overheating (14 replies)
  224. Teflon hose and fittings (3 replies)
  225. How to make a sumped tank? (20 replies)
  226. Anybody using new Spectra GM32BFI tank with internal baffles and sump? (2 replies)
  227. Anybody Good with holley Pro-Jection systems? (4 replies)
  228. Anybody familiar with BigStuff 3 (0 replies)
  229. any 1st gen camaro's running sumped tank external fuel pumps with ls swap (4 replies)
  230. Which fuel tank should use? (7 replies)
  231. '63 Vette Fuel Injection (3 replies)
  232. Aftermarket EFI with OBD2? (10 replies)
  233. What is this fitting? (10 replies)
  234. Fuel rail options for Fast Manifold (3 replies)
  235. Use older FAST system or get the newer XFI? (2 replies)
  236. any one running spectra gm32 tank in 1st gen camaro (3 replies)
  237. Aluminum Intake runner - gauge size? (1 replies)
  238. Aftermarket EFI + catalytic converters + CA legal (3 replies)
  239. EZ EFI idle drops significantly when in gear... (9 replies)
  240. GM LS Computer Running Older Engine...Possible? (7 replies)
  241. Fuel Regulator & Filter selection for LS (6 replies)
  242. Throttle bodies with TH 350, 200R stud placement (6 replies)
  243. Hardline vs. Teflon Braided (38 replies)
  244. Help with Pictures on Your Fuel Line Routing at the Motor (2 replies)
  245. Still running really cold (2 replies)
  246. Fast crank trigger 301180 (5 replies)
  247. What Fuel Filter to Install? (3 replies)
  248. MAT sensor location (4 replies)
  249. EFI 58x and 24x Relutor crank sensor for Early SBC (10 replies)
  250. EFI intake options for vortec heads (3 replies)
