View Full Version : What is this fitting?
CFster
03-08-2011, 05:48 PM
I have a Spectra EFI tank I'm installing and I don't know what this fitting is:
45208
45207
It came with this adapter, but they don't really expect me to use a barbed fitting do they?
45209
45210
It's not -6 or -8.
:banghead:
THE TECH
03-08-2011, 06:05 PM
Looks like a return for a return fuel system.
dhutton
03-08-2011, 06:24 PM
I think it is an SAE 45 degree fitting.
CFster
03-08-2011, 06:26 PM
It's the larger of the two lines.
theRG
03-08-2011, 06:58 PM
3/8" you can get an -AN adapter, should be a 3/8 to -6.
MrForce
03-08-2011, 06:59 PM
Socketless fitting for EFI hose. Does not require a clamp.
CFster
03-08-2011, 07:04 PM
Isn't 45 degree flare only for low pressure applications?
theRG
03-08-2011, 07:56 PM
They make automotive double 45 degree fittings for high and low pressure, your adapter being the low pressure variety so I'm guessing your male fitting also is. Don't work much with 45 stuff so I was just commenting on size, and you mentioned -AN sizes -6 or -8 I thought you were just looking for a way to adapt the two to run braided line. What fuel system you running.
CFster
03-08-2011, 08:12 PM
I want to plug hose with a -6 AN fitting into the 45 degree flare coming off the tank.
CarlC
03-08-2011, 09:08 PM
As noted above, that appears to be an SAE 45*.
If you decide to use the barbed fitting with a push-on hose/clamp be sure to use a high-pressure fuel injection rated hose.
Here's the part you will need to adapt to a -6 http://www.purechoicemotorsports.com/index.cfm/page/ptype=product/product_id=325/category_id=130/home_id=-1/mode=prod/prd325.htm
CFster
03-10-2011, 07:30 PM
Thanks Carl. Ordered.
