View Full Version : Tubetech nylon fuel line???
BuddyP
08-30-2011, 05:05 PM
What's the scoop with tube tech's nylon fuel line? Good? Bad? Should I stick with a stainless solid tube setup instead?
wedgehead
08-30-2011, 06:59 PM
I have used nylon tubing on several cars with great results. I use a dorman kit to install the needed ends onto the lines.
Ollie8974
08-31-2011, 05:12 AM
This is a discussion about nylon fuel lines over on LS1 Tech forums.
Post #19 in the link below.
http://ls1tech.com/forums/fueling-injection/1085884-nylon-fuel-line-fitting-attachment.html
MuscleRodz
08-31-2011, 12:49 PM
you can get the plastic fuel line repair kits from your local part store. Howvwer, i would still use hardline as much as possible for maximum protection
