View Full Version : 2010 camaro pump and Ricks Tanks
67church
05-17-2011, 10:46 AM
I have the new Vaporworks tank by Ricks hot rods.....Very nice! My question is about the fuel pump connector. I have the part number 92202097 priced out but it is very expensive for not needing the whole harness. Has anyone been able to locate just the connector and pig tail vs. the whole harness at 90$ a shot?
Any leads on part numbers or phone numbers would greatly be appreciated.
Chuck
1bad68cat
05-17-2011, 11:07 AM
These are the parts I used for a 2007 silverado fuel pump module that i think are the same as the 2010 camaro module. The are the individual pieces for a GT 280 series connector.
http://www.mouser.com/Search/ProductDetail.aspx?R=12191235virtualkey63000000vir tualkey829-12191235 - seals
http://www.mouser.com/Search/ProductDetail.aspx?R=15326004virtualkey63000000vir tualkey829-15326004 - pins
http://www.mouser.com/Search/ProductDetail.aspx?R=13521459virtualkey63000000vir tualkey829-13521459 - housing
67church
05-17-2011, 11:11 AM
Thank you Very Much!!!
CarlC
05-17-2011, 03:29 PM
That connector will not work. Been there, done that.
If you are running the module with the 4th-gen mechanical regulator as supplied from Rick's then I can supply a complete harness. The harness has a OE plug for the module, a quick-disconnect plug so that the wiring can be disconnected near where the wiring passes through the aft trunk floor, and 5' of GXL wire past the quick connect. PM me if you are interested.
ErikLS2
05-17-2011, 04:09 PM
I would just get the one from Carl. That's what I got and it's plug it in and go.
