View Full Version : tunnel ram with dual tp doable???i
chpr1972
11-01-2012, 08:14 PM
what system would be better and how bad would dual tpi,s hurt gas miliage this car will be a daily driver 496 bb chev muncie 4 speed 350 ford 9" tire size of about 25 1/2 in tall in a 66 lemans conv
64duece
11-03-2012, 05:31 AM
It's very good option. You can run either twin TBI's or dual air valves with port injection below. While either setup can be tuned better than carbs for economy...the sequential port injection would get the edge.
BuzzKillian
11-03-2012, 07:20 AM
I agree with Dennis, but with a 496,are you really worried about gas milage? With that in mind, you spend your money better on a good OD transmission.
64duece
11-03-2012, 08:12 AM
No doubt the OD and EFI would be an ideal combination. Especially w/ a lockup converter. I've bested 12.9mpg on e85 w/ 572" Twin Turbo BBC. Granted it has a very mild cam and not much gear needed. I've spent alot of time working on fuel milage tuning...it takes some work but worth the effort in the end.
SS PUNISHER
11-03-2012, 09:11 AM
I'd say that's impressive considering it's on e85...
andrewb70
11-03-2012, 11:05 AM
Dennis,
I assume this was with the new Holley Dominator system?
64duece
11-03-2012, 07:05 PM
Dennis,
Correct...it shows real time fuel economy as the system knows fuel/lbs hr and speed from the 4L80E. I back that up with the normal milage vs gals as well...worked out nearly spot on.
MrForce
11-05-2012, 08:20 AM
very doable
67120
Skip Fix
11-05-2012, 11:37 AM
I remember seeing a few years back a Hemi dual quad where they plumbed the injectors underneath and modded some carbs to just be air valves with a TPS.
