View Full Version : Gas tank question/ Holley avenger EFI
daveybtv
09-05-2011, 04:03 AM
I want to ditch the old carb on my 1979 Malibu and update to the Holley Avenger EFI set up but I have never been a fan of the external fuel pump. So I was wondering if I could use a 86-88 Monte Carlo or Grand National stock tank with internal pump? this should be a direct bolt in and all I would have to do is run a power to the pump and a return line, right? Or do you see any other mods that would need to be done?
Ollie8974
09-05-2011, 05:47 AM
Do you know how deep the Malibu tank is?
If it is 9 to 10 inches deep, Install a 4th gen fuel pump module.
This is the fuel pump mod I am using on a 79 TA.
http://www.vetteworksonline.com/ls1_conversion_fuel.htm
BulldawgMusclecars
09-06-2011, 08:48 AM
As long as your Malibu isn't a wagon, you could just switch out the sending unit for one with a fuel pump assembly (as found on 4.3 TBI Montes and 3.8 turbo Buicks). If you go with the Monte setup, you'll have to change to a high pressure pump, but a stock GN one or an aftermarket repalcement should be adequate. Be sure to run a good (large) power wire for the pump.
daveybtv
09-08-2011, 08:35 AM
Thanks! I thght this would work good know I dont have to switch tanks though..cool, now I just have to find the money for the EFI!
