View Full Version : fuel pressure regulator?
BuddyP
08-31-2011, 06:26 AM
Have a 6.0 LS motor with Ricks tank (internal pump). Getting ready to run fuel lines but not sure where to go with a regulator??
boostin05blacksti
08-31-2011, 06:38 AM
waiting to see what others have to say as Ill be in this boat soon. Also what regulator did you go with? Part number? Thanks Steven
MuscleRodz
08-31-2011, 12:47 PM
most used and simplest deal is a 98-05 corvette regulator and filter. you will need adapter fittings and those you can get from russell
badazz81z28
06-16-2012, 06:07 PM
Do you know the part #? I need a regulator too for my 1978 camaro LS swap.
68sixspeed
06-16-2012, 07:00 PM
The filter has the regulator built in. Speedway has a kit with the an adapter fittings, works great.
http://www.speedwaymotors.com/LS1-Fuel-Filter-Regulator-Kit,41791.html
badazz81z28
06-17-2012, 07:59 AM
Thank you so much for posting that. I see so many old threads about alot of parts I'm looking for and they never have the part #!
V/R Rob
badazz81z28
06-19-2012, 08:43 AM
Do you know what the kit comes with? I see the filter/regulator is $30, but for $70 it looks like you only get 1 extra fitting for the fuel rail?
68Formula
06-19-2012, 10:05 AM
Looks like the kit includes quick-connect to AN adapters for the regulator inlet and return, plus the fuel rail fitting.
badazz81z28
06-20-2012, 02:29 PM
I may just buy the filter seperate...I hate blue AN fittings lol...
68sixspeed
06-20-2012, 05:39 PM
I called speedway and they entered the order with black fittings.
You should only need the one extra fitting at the fuel rail unless you have an older ls1, most of the newer stuff does the return line at the filter and only runs a pressure line to the engine and fuel rail.
badazz81z28
06-20-2012, 06:21 PM
I have an 02 f-body type of set-up. Looks like if all I need is that fuel rail fitting, I can get that for a few bucks at Summit. I would hate to spend an additonal $40 for some fittings I'm not going to use.
Please correct me if I'm wrong here:
I need this for the rail: http://www.summitracing.com/parts/RUS-640853/
The filter
and just the associated hose/AN fittings to plumb it.
68sixspeed
06-21-2012, 10:02 AM
You won't need the extra fitting from summit if you get the speedway kit, they give you 4 fittings with the filter/regulator, 3 for use on the filter and one for at the fuel rail push on. But if you are going to get just the filter, then you will need the russell fitting from summit, plus whatever other fittings or Dorman hose ends to connect to the filter/regulator.
The WidowMaker
07-15-2012, 08:38 AM
anybody know the flow rating? it looks like it comes with -6 fittings. anybody used this with -8 lines? i was just about to pick up an edelbrock 10 micron filter, but hadnt got to the regulator yet.
Ollie8974
07-16-2012, 05:33 AM
Don't use those old style Russell fittings,
This is the new style PN is RUS. 646110
The new style has the threaded "U" lock ring.
evostilo
07-16-2012, 01:18 PM
any one have pics of this and how close to ur gas tank/fule pump did you put the regulator?
The WidowMaker
07-16-2012, 01:48 PM
is this the only filter and reg you guys are running? running close to the tank or up front? dead headed into fuel rails with no return? it looks like russel makes the old style in -8 that will fit the reg. not sure about the new style.
Ollie8974
07-16-2012, 02:20 PM
Russell offers the new style in both -6 and -8.
Blue or Black.
armourmark
07-17-2012, 05:53 PM
Look at my thread. I have all the part numbers for the filter and fittings you will need in black from summit.
https://www.pro-touring.com/showthread.php?91141-67-RS-w-LQ4-and-Tanks-Inc-fuel-system
