View Full Version : my olds 455 efi conversion
hessdawg
08-17-2011, 12:15 AM
started with some tech drawings
https://static1.pt-content.com/images/pt/2011/08/48256a2c-1.jpg
measured fuel rail drill points
https://static1.pt-content.com/images/pt/2011/08/a50b8cc5-1.jpg
drilled fuel rail pilots
https://static1.pt-content.com/images/pt/2011/08/ebab52a1-1.jpg
set up intake on drill
https://static1.pt-content.com/images/pt/2011/08/1a38e25f-1.jpg
all drilled out
https://static1.pt-content.com/images/pt/2011/08/6e076d73-1.jpg
epoxying the bungs in
https://static1.pt-content.com/images/pt/2011/08/IMG_0900-1.jpg
grind and re-epoxy underside
https://static1.pt-content.com/images/pt/2011/08/IMG_0905-1.jpg
checking to see if i have room with a 2 inch spacer
https://static1.pt-content.com/images/pt/2011/08/IMG_0896-1.jpg
https://static1.pt-content.com/images/pt/2011/08/IMG_0893-1.jpg
tapped up for paint
https://static1.pt-content.com/images/pt/2011/08/IMG_0917-1.jpg
por 15 black sprayed
https://static1.pt-content.com/images/pt/2011/08/IMG_0929-2.jpg
por15 engine enamel aluminium
https://static1.pt-content.com/images/pt/2011/08/IMG_0932-1.jpg
Roadrage David
08-19-2011, 09:58 PM
that is so cool will the Por 15 hold due to the heat???.
hessdawg
08-21-2011, 07:58 PM
yes that's what the recommend
hessdawg
08-23-2011, 07:36 PM
got the valve covers on
https://static1.pt-content.com/images/pt/2011/08/4c3844ea-1.jpg
got fuel rail mounted
https://static1.pt-content.com/images/pt/2011/08/73eab64e-1.jpg
https://static1.pt-content.com/images/pt/2011/08/60badafa-1.jpg
got injectors wired and pcv run
https://static1.pt-content.com/images/pt/2011/08/969f5877-1.jpg
72BBSwinger
08-24-2011, 11:43 AM
Love the do it yourself injector bungs. Very motivating.
Yelcamino
08-28-2011, 03:42 AM
Everything looks great, just curious though, why did you choose to epoxy the bungs vs welding?
hessdawg
08-30-2011, 12:10 AM
well i wanted to weld but i don't have a tig and couldn't find a shop to do it for me.
i had also seen many guys do it on the megesquirt forums so if it good enough for them its good enough for me
rohrt
08-30-2011, 05:58 AM
Coool!
Ollie8974
08-30-2011, 05:59 AM
2X on the epoxy vs welding. Helps keep the cost down. Especially if you hav to pay someone to do the welding.
hessdawg,
What brand epoxy did you use.
John Wright
08-30-2011, 06:15 AM
Neat project....the fuel rails polished up nice.
What determines the length of those injector bosses? I've seen them where the injector tip is sticking out into the intake runner quite a ways and then others are way up inside the boss and can't be seen, like these.
Ollie8974
08-30-2011, 06:27 AM
I would say the design of the manifold. The installed height of the injectors should all be the same so that the injectors all plug into the fuel rail equally.
hessdawg
08-30-2011, 12:02 PM
hessdawg,
i used what everybody else that i talked to had used. the jbweld regular not quick
hessdawg
08-30-2011, 12:05 PM
depending on the spray pattern of the injector.you usually want to tip of the injector flush with the intake runner
Yelcamino
08-30-2011, 05:05 PM
Ok, I was just wondering is all.
bsilverblatt
04-09-2013, 04:54 PM
Sorry to resurrect an old thread, but I was wondering where you got these technical drawings from... [QUOTE=hessdawg;828174]started with some tech drawings https://static1.pt-content.com/images/noimg.gif
hessdawg
05-29-2013, 08:51 PM
They were in the back of a monello book
hessdawg
04-08-2014, 07:10 AM
In the car and running, but still needs some work
http://youtu.be/Y_GcjQgP4tk
HurstOlds
05-16-2014, 10:23 AM
Really nice setup!
I've been kicking around the idea of converting my 455 over to an EFI setup. Have you posted more in depth details on your setup elsewhere? You mentioned you're using a MegaSquirt setup?
What's your increase in MPG after you converted? I currently get around 8 mpg with my carb setup. That's what I'm mainly looking to improve upon
Derek@ModernSpeed
05-20-2014, 10:35 PM
I may have missed it, what electronics are you using?
Ollie8974
05-21-2014, 04:39 AM
He is using MegaSquirt.
hessdawg
05-22-2014, 11:17 PM
Really nice setup!
Haven't done a in depth build. log let me know if you have any questions on the set up
I had a Holley 926 and I would usually get around 7 or 8 mpg with a th350 and a 3.23 rear end
When I swapped to Holley projection tbi and a 200r4 with the same rear end it the best I got was 17mpg
It now has full sequential fuel and spark ms3x same 200r4 I'd like to go to a t56 double overdrive
But I now have a 4.11 rear end. Car isn't on The road yet so im not sure what what my mpg will be
hessdawg
Ollie is correct a ms3x from megasquirt
hessdawg
08-16-2014, 05:42 PM
Engine in the car
Plumbed and wired
https://static1.pt-content.com/images/pt/2014/04/e01cea81dc8941d4d7b43aa300e8711f-1.jpg
Dusted
03-24-2015, 07:48 PM
More pics soon?
