View Full Version : Edelbrock Fuel Injection Manifold for Mustang 5.0 - Question
Dr G
03-13-2012, 12:17 PM
Hello - I just bought an Edelbrock fuel injection manifold for the 302 based 347 in my 56 F100. Currently the engine has an Edelbrock Air Gap manifold with a Holly 4150.
The new manifod has some features that I do not currently have. And I am trying to figure out what they are for so I can assess how to deal with them.
https://static1.pt-content.com/images/pt/2012/03/lowerintake21-1.jpg
Regarding the large hole in the backside of the manifold. It leads into the lifter valley. What is this for? Exhaust gas recirculation? I assume I can just block this off.
Then there is this circtuitous passage leading from the throttle body area to the cylinder head shown in these two photos (entrance and exit):
https://static1.pt-content.com/images/pt/2012/03/upperintake11-1.jpg
https://static1.pt-content.com/images/pt/2012/03/lowerintake31-1.jpg
I am not even sure that the heads on my engine have anything for this passage to lead into. I was planning to also block this off.
It would be good to know what these features are intended for, so that I can be confident in ignoring them. If anyone can lend assistance it would be most appreciated.
Gustave
67TXStang
03-13-2012, 05:43 PM
There is normally the port between the intake runners on the intake. It is often referred to as the 'exhaust crossover'. My aftermarket heads (Edelbrock) don't have a matching port but the stock heads did. It allows some exhaust gas to flow into the intake to help the engine warm up faster.
The Fel-Pro intake gaskets I've purchased (1250) aways include a block off gasket for this port. I blocked mine off.
I'm not sure about the others.
Dr G
03-14-2012, 01:31 PM
I'm not sure about the others.OK, thanks. That may well be it. Some part of the EGR process. Since I do not have the throttle body transition, which contains much of the emmisions connections, it is difficult to know more until I pull the existing intake off and look at the heads.
The other large hole I asked about turns out to be for the positive crankcase ventilation system (PCV). I'll probably route that to the exhaust.
Gustave
RSX302
03-21-2012, 09:09 PM
Gustave
Correct, the hole in the intake is emisions related (EGR) and pulls from the exhaust ports in the heads. Not needed for non emisions vehicles.
"The other large hole I asked about turns out to be for the positive crankcase ventilation system (PCV). I'll probably route that to the exhaust."
Should go to intake not exhaust..
