View Full Version : help me... I dont know whats right on FPR
qnitro
05-16-2013, 01:54 PM
All,
I am replacing the old stock LS6 fule rails with fast fuel rail and fuel pressure reg.. Im not sure how to run the lines?? I have a corvette fuel filter.. so I only have a single feed line to my rail.. I have searched everywhere and see no configuration for this.. I built a quick visio(saved as jpg) to show what I think I should build.. Is this correct?? Do I need to have a return line back to FPR? Help me understand :)
CarlC
05-16-2013, 03:09 PM
In your diagram you have two pressure regulators, the C5 part and the part that you note on the fuel rail. Do not use two fuel pressure regulators in a single system. If you need to have the manifold referanced fuel pressure regulator then eliminate the C5 part and use an in-line filter from a 90's GM truck. Also be sure to verify if the return line goes back to the regulator or to the tank.
If you can use a non-manifold referanced FPR then eliminate the rail mounted setup, put front and rear fuel rail crossover lines in place, and connect to the fuel rail from the C5 part using a single line. The C5 part will need to have a return to the tank.
There is info here as well http://vaporworx.com/fuel_delivery_101.htm and http://vaporworx.com/fuel_pressure_regulators.htm
Rhino
05-16-2013, 03:35 PM
I'm wondering if whoever made that pic was referring to the stock fuel rails on the later model LS1's. While it may look like a regulator, it's only there for helping in balancing the cylinder banks.
qnitro
05-16-2013, 06:05 PM
Ahhh, the corvette fuel filter is a regulator as well.. COol, so I will just drop the line on the fuel rails and be done with it??
qnitro
05-16-2013, 06:06 PM
No Im adding fast fuel rails.. So it looks like I dont need the fast FPR..
andrewb70
05-16-2013, 06:22 PM
Correct. Also, on the Corvette regulator, the return line is the middle one, on the end that has two lines. The single line is the outlet that goes to your fuel rail.
qnitro
05-16-2013, 07:34 PM
Sweet... Thats makes it easy
icemanrd19
05-31-2013, 07:47 PM
so using a stock corvette fuel filter i run a feed in the one side, return in the same side, and a engine feed out the other and i do not need a FPR on the firewall? This is for a ls3.
like this
Here you will see the Wix filter/regulator (summit part #WIX-33737) and the fittings needed to make the connections. The brass is a 5/16 compression to a 3/8 hose barb that I made up at my local hardware store for the return line. The supply is a russell quick connect fuel fitting (RUS-644123) with a straight AN -6 fitting. On the outlet side, it is the Russell fuel rail adapter fitting (RUS-640940) and then a straight -6 AN fitting.
http://www.speedwaymotors.com/LS1-Fuel-Filter-Fuel-Regulator-Kit,41791.html
doesnt this have the cheap plastic clips that might break?
qnitro
05-31-2013, 11:52 PM
Im thinking yes.. I think the corvette fuel filter is regulated at 58psi..And the ls3 is around the same Can anyone confirm? But I think your good
tooblue
06-01-2013, 12:32 AM
That is correct.. Roger
