View Full Version : TPS Values - not what I expected
esenior
10-09-2011, 06:03 PM
I hooked my laptop up to my F.A.S.T. ECU tonight (old one, not XFI) to see if it was communicating. I noticed that the TPS value is at 79% when the pedal isn't depressed and drops to ~40% when the pedal is dropped to the floor. Shouldn't the TPS % value increase not decrease? Anyone see a problem with only a 40% swing?
CFster
10-09-2011, 06:28 PM
Not sure what your setup is, but I know in some fly-by-wire applications if the TPS signal is taken from the pedal sensor the values are reversed. As a matter of fact my Compushift controller has a setting to take this into account. Also, on said pedal sensor there are two sensor signals (wires), and one has a significantly narrower range than the other.
Mike Norris
10-10-2011, 03:53 AM
I would be curious to see what you TPS calibration looks like. If you can do a screen shot of the TPS cal it might be helpful.
John Wright
10-10-2011, 04:44 AM
Maybe check the voltage values instead and see what the computer is seeing.
MrForce
10-11-2011, 09:16 AM
At best power and ground are reversed. Or all three are pinned wrong. The FAST Classic cannot calibrate TPS. Typical readings are ~5-8% at idle and above 95% at WOT.
Rob
camcojb
10-12-2011, 07:45 PM
Rob
yep, been there, seen that before. :)
esenior
10-12-2011, 08:28 PM
OK...took the sensor off and started checking the wires. I didn't know the pinout of the 06681 TPS so tried a few different configurations. Rob was correct...Found out that all 3 connections were wrong and the FAST manual is incorrect (possibly meant for a different sensor). I'm now getting 2% at idle and ~70% at WOT. Thinking I'm going to need to move the throttle cable connection closer to the throttle pivot to get closer to that 95% mark, but at least I'm getting the correct response now.
