View Full Version : II Much Vent in a Sec Gen Camaro?
badazz81z28
12-06-2012, 10:45 AM
Who has one installed? I can't seem to find a location to put one. Yhe truck appears to have a good flat spot, but its not flat underneath,
carbuff
12-06-2012, 08:15 PM
Hmm... I've purchased two of them, but have not installed them yet. What about on the sides instead of in the main floor pan? I seem to recall that those areas are flat from the installation of a trunk-mounted battery...
badazz81z28
12-11-2012, 11:29 AM
Nobody huh? I looked on the sides...I'm stumped
carbuff
12-11-2012, 02:20 PM
Can you say what doesn't work about mounting them on the sides? I thought for sure those areas were flat...
badazz81z28
12-11-2012, 07:35 PM
Yes, the area is nice and flat in the trunk, but its not under the car. On the sides, that's where the frame is and rest of it is directly above the tank.
JohnUlaszek
12-17-2012, 11:00 AM
Can you post up some photos? We've had them installed with success on early second gens but I know they made some changes in later years.
badazz81z28
12-19-2012, 06:53 PM
Here you go. How big is the lock ring?
https://static1.pt-content.com/images/pt/2012/12/pic1_zpse153ec74-1.jpg
badazz81z28
12-19-2012, 06:54 PM
Do you have any pictures of early sec gens installed?
carbuff
01-24-2013, 09:52 AM
Have you decided where to mount the can yet?
On my project, we decided to mount a pair of the cans in the area of the picture above. I don't know if your car has this or not, but my car had some kind of sealed vent tank in a pocket behind the rear seat, right above the center section. It was held in by a couple of spot welds. I drilled those out and removed the tank, and there is an opening from there to under the car. The hoses come out of an opening in that second level of the panel which you are also having a problem with.
So we cut out an opening slightly larger than what existed on the car, and cut open an area large enough to access the bottom of the 2 cans in the panel shown above. We're also making a 'mount' for the 2 cans which will be bolted to the floor which will allow me to remove the whole assembly if I ever need to take them back out for some reason.
I don't have pictures yet, but I will this weekend. It's going to be just about a perfect spot for me, although I wasn't thrilled about cutting that panel. Now that we have though, it seems like it was the right choice.
My previous idea of mounting them off to the side wouldn't work as there was not a good way to run the hoses downhill the whole way. Also the tire would through stuff right at the bottom of the can, which wouldn't be good either...
amargari
01-24-2013, 04:26 PM
Have you tried to put it where the factory vent was? I think that is what carbuff is suggesting.
https://static1.pt-content.com/images/pt/2013/01/GasThing-1.jpg
badazz81z28
01-24-2013, 06:05 PM
The later Sec Gen Camaros have a charcoal can in the engine bay. I dont have that device behind the seat.
71RS/SS396
01-25-2013, 07:45 AM
This might be a better solution in your situation https://www.pro-touring.com/showthread.php?96036-finch-dual-vent-system
badazz81z28
01-25-2013, 06:44 PM
Thanks for the Tip! I emailed Brian about it. I must say, its kind of odd that he hasn't posted anything about it here nor is it listed on his website.
amargari
01-29-2013, 07:07 PM
Didn't know that. Thanks for the education.
icemanrd19
01-30-2013, 06:17 AM
he has been busy testing the new bfg tire. Im sure he will post something soon.
badazz81z28
01-30-2013, 08:18 AM
I ended up buying Finch's vent. I can simply drill small holes for the lines rather than one big one for the entire unit. The good thing is it doesnt matter what the sheet metal looks like under the trunk because all I need in the trunk is a flat spot to mount it (which there is).
carbuff
01-30-2013, 09:41 PM
Sounds like you have a solution, but here's a followup pic of how we are mounting mine. They aren't in the picture obviously, but you can see the mounting plate and location:
https://static1.pt-content.com/images/pt/2013/01/update_0130_16_zps3b866f22-1.jpg
https://static1.pt-content.com/images/pt/2013/01/update_0130_17_zpsdb2d09a0-1.jpg
Motown 454
01-31-2013, 08:22 PM
It looks like a nice spot for them Bryan.
JohnUlaszek
02-03-2013, 09:16 AM
Great looking fab work, if you get a chance, post up a pics with the vents installed.
BBPanel
02-03-2013, 11:25 AM
I assume the vent(s) should be mounted above the fuel door entry opening correct? Any liquid will seek its level - that same relative spot on my Nova may not be above the filler opening - need to check.
parsonsj
02-03-2013, 01:07 PM
I assume the vent(s) should be mounted above the fuel door entry openingNot quite. It needs to be above the vent port opening in the tank. You don't want to be filling your tank to the point where you have the fuel level all the way up to the gas cap. In fact, that's actually pretty hard to do with most filling station nozzles. You would need to "top off" the tank several times to get the tank that full, and most OEM tanks will vent gasoline on to the ground in that situation.
BBPanel
02-03-2013, 08:33 PM
.... In fact, that's actually pretty hard to do with most filling station nozzles.....
I've often wondered how the nozzles detect that - do you know how?
carbuff
03-04-2013, 03:52 PM
As requested:
https://static1.pt-content.com/images/pt/2013/03/update_0303_03_zps7e998427-1.jpg
https://static1.pt-content.com/images/pt/2013/03/update_0303_04_zpsee31f25f-1.jpg
https://static1.pt-content.com/images/pt/2013/03/update_0303_05_zps71644d6a-1.jpg
https://static1.pt-content.com/images/pt/2013/03/update_0303_06_zpsf4abaa3d-1.jpg
https://static1.pt-content.com/images/pt/2013/03/update_0303_18_zpscd6d73c0-1.jpg
parsonsj
03-04-2013, 07:23 PM
Bryan, that's nice work. Really nice work.
carbuff
03-04-2013, 08:29 PM
I wish I could take credit for it, but that's all on Eric! :) And I agree, it's really nice work! His patience and attention to detail are awesome!
Bygblok
03-08-2013, 11:19 AM
I'm going to a FAST system in my 70 model and it vents through the gas cap. Not sure how I'm going to run my return line yet but since it's not vented to a canister what kind of problems could it pose for me once it's up and running?
