woody80z28
10-03-2012, 08:03 AM
Right now I'm running a carb and I have a pump feed line to the return reg, and a return line to the tank and a feed line to the carb coming out of the regulator. In theory, I should be able to do basically the same thing with the rails, correct? The regulator will only bypass fuel if there is enough pressure in the rail to overcome the spring.
Aesthetically it would look best with the regulator on the pass front end of the rail with a crossover in back and the driver front end plugged with no ugly crossover up front or feed in one end and return out the other. Is this likely to give me pressure issues with the #1,3,5,7 cylinders since the regulator is so far away?
